Old 06-25-2009, 08:51 AM   #1
1964C10
1964C10's Avatar
How to question
I am planning on going to the junk yard today to find the parts to do the front power disc brake setup (spindles, arms, tie rods etc). My question is, while I am there how do I get the upper/lower arms apart with the spring knocking me in the head? At home I have the jack to do that, I was wondering if there was a trick or do I need to bring a bottle jack, wooded blocks and so on? Thanks all!
1964 Fleetside LWB
1995 Yellow Mustang convertible
1996 Camaro Z28
My build thread
Looking for help on completing the Disc Brake Upgrade Reference Thread
If you didn't build it, you don't really own it
1964C10 is offline   Reply With Quote
Old 06-25-2009, 08:59 AM   #2
1964C10
1964C10's Avatar
Re: How to questionp
Sorry about the subject line, guess that is something that you can not edit.
1964 Fleetside LWB
1996 Camaro Z28
My build thread
Old 06-25-2009, 09:51 AM   #3
jason65
Registerd User
jason65's Avatar
I would use a jack on the crossmember. Lower a-arms on the ground. Remove lower ball joint nut. Wack the chet out of it till it breaks loose. Remove nut. Jack it up slowly till the springs fall out.
jason65 is offline   Reply With Quote
Old 06-25-2009, 09:51 AM   #4
daverod
SSN 706
daverod's Avatar
I taped my grinder on a stick stood back about 8' and cut the u bolts.I know it's not the right way to do it but it's my way and it worked. Did'nt really seem like there was a lot of pressure on them anyways. I think they make a spring compressor that you rent from Auto Zone. I was to just lazy to get one. You could hook a chain around it and hook it to something if you think it going to come flying out of there.
daverod is offline   Reply With Quote
Old 06-25-2009, 10:33 AM   #5
1964C10
1964C10's Avatar
Thanks guys! Now that you mean it I do have a spring compressor that I used for my mustang, I'll see if it fits. They work good just take forever to get them on and off, but better then losing a body part lol.
1964 Fleetside LWB
1996 Camaro Z28
My build thread
Old 06-25-2009, 01:14 PM   #6
SIR
SIR
SIR's Avatar
..find a 72 if possable,borrow there torch cut the frame off at the firewall and take the whole thing home and disassemble it at your leasure...my "02"..
66long low fleet http://community.webshots.com/user/LVNR66
SIR is offline   Reply With Quote
Old 06-25-2009, 01:49 PM   #7
70 Suburban
Rods
LOL dont take the nut off. Just loosen it up Whack it on the flat spot on the spindle. The nut will stop it form coming off. then put your jack under it use a 1/2 long handle ratchet and take the nut off.
Just keepin it simple.
1965 C-10 Ext cab build. 350??(Does it count at 2 truck if I had to cut one up?)
1966 C-10 lwb 283 auto
1970 Suburban in pieces
1971 Blazer 4wd....restore someday. all factory CST
1972 Blazer 4wd parts truck still a roller
1972 GMC Sierra Grandee
1998 Chevy ext driver.
2005 F**D the wife drive...(cant fix women)
70 Suburban is offline   Reply With Quote
Old 06-25-2009, 02:52 PM   #8
jason65
Registerd User
jason65's Avatar
I know. Edit time ran out.
Old 06-25-2009, 03:13 PM   #9
1964C10
1964C10's Avatar
Good idea, maybe in conjunction with the spring compressor and a jack it will be "safe" lol
1964 Fleetside LWB
1996 Camaro Z28
My build thread
Old 06-25-2009, 03:14 PM   #10
1964C10
1964C10's Avatar
That would be the ideal situation but I have no way to transport it home. The bed is off my truck and I dont know anyone crazy enough to let me drop a greasy, rusty old front end in their truck/van hahahaha...I need new friends
1964 Fleetside LWB
1996 Camaro Z28
My build thread
Old 06-25-2009, 04:31 PM   #11
joe231
joe231's Avatar
just tie some rope around the spring then tie it to the frame so it can't jump out.....take the lower ball joint nut off and swing your BFH, as you stay out of the way of the lower arm.....
I went and got a spindle from a junk yard, the guy pulled it with a pair of pliers, adjustable wrench, and a BFH
as stated previously, there doesn't seem to be much tension.
CHEVY ONLY
joe231 is offline   Reply With Quote
Old 06-25-2009, 05:05 PM   #12
1964C10
1964C10's Avatar
Hope that will be true for me ...doesn't look like today though, I am still working.......at least my plans for my truck are going better then my plans to be independently wealthy
1964 Fleetside LWB
1996 Camaro Z28
My build thread
Old 06-25-2009, 06:00 PM   #13
joe231
joe231's Avatar
you get the second deal figured out, please let me know
CHEVY ONLY
Old 06-25-2009, 06:08 PM   #14
1964C10
1964C10's Avatar
I am sure that this truck is not a good "financial" investment
1964 Fleetside LWB
1996 Camaro Z28
My build thread
Old 06-25-2009, 06:23 PM   #15
daverod
SSN 706
daverod's Avatar
Old 06-25-2009, 06:31 PM   #16
daverod
SSN 706
daverod's Avatar
Originally Posted by daverod View Post
I did'nt read you have no way of tranporting it.You mean you hav'nt cut your parts truck in half and made a trailer out of it yet?
Old 06-25-2009, 06:37 PM   #17
1964C10
1964C10's Avatar
Hahahaha...no parts truck here....I dont really live in a neighborhood where I have room for things like that. I have also been reading up on all the parts I will need and I am still a little confused, so more research needed. I am going to be running discs with a power booster, but I would like to have the 73-87 parts (I think the years are correct) so that replacement parts are more abundent.
1964 Fleetside LWB
1996 Camaro Z28
My build thread
Old 06-25-2009, 06:42 PM   #18
daverod
SSN 706
daverod's Avatar
71 and 72 will work also. If your hard up.
Old 06-25-2009, 06:45 PM   #19
1964C10
1964C10's Avatar
It's not an urgency so if I have to find some parts now and get some later then that is fine as well, but thanks for the heads up, I am adding it to my list of potential parts.
1964 Fleetside LWB
1996 Camaro Z28
My build thread
Old 06-25-2009, 11:53 PM   #20
Captainfab
60-66 Nut
Most guys go for the '73-'87's partly because they are more abundant in the salvage/junk yards. I seem to remember that the lower balljoint for the '71-'72's are more expensive than the '73-'87's also.
Old 06-26-2009, 12:16 AM   #21
daverod
SSN 706
daverod's Avatar
The lowers are the same the uppers are a $14 difference.
Old 06-26-2009, 12:22 AM   #22
1964C10
1964C10's Avatar
Thanks guys, one step closer, well probably two since I know what I am hunting for.
1964 Fleetside LWB
1996 Camaro Z28
My build thread
Old 06-26-2009, 09:21 AM   #23
Chevy Fleetside
Chevy Fleetside's Avatar
I would let you drop it in my truck. But then again the comute might be rough,..
"A man and his truck, what a beautiful thing"
65 Short Fleetside BBC
65 Long Fleetside 283 3 on the tree for now.
my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536
Chevy Fleetside is offline   Reply With Quote
Old 06-26-2009, 09:24 AM   #24
daverod
SSN 706
daverod's Avatar
Nice offer. What about tieing it on top of the old ladies car. I saw a guy at the lumber store with a 6x16 beam on his wagon.
Old 06-26-2009, 09:52 AM   #25
1964C10
1964C10's Avatar
thanks for the offer fleetside! that is most gracious! what I might end up doing is renting a truck from Lowe's I think they are like $20/hour.
1964 Fleetside LWB
1996 Camaro Z28
My build thread
