Leaf to Coil Swap
Anyone got a how to or info on how to do this, any pics?
Mitch 22yrs. Young 1970 GMC Short-Step 350/TH350 Combo. . ![]() Current Project 68 Gmc "Second Chance" Go to my 68 GMC Shorty Rebuild Thread http://67-72chevytrucks.com/vboard/s...39#post6341739 |
Under Construction
Re: Leaf to Coil Swap
I have seen some leaf spring trucks that had the trailing arm crossmember in place. Is this the case on your truck?
Heath subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php http://67-72chevytrucks.com/vboard/s...d.php?t=157669 FAQ how to's 1956 Chevy Apache 1967 C10 SWB FleetSide (under construction) 1969 K10 SWB FleetSide (Future Build) 1972 C10 SWB Stepside (Future Build) 56 chevy truck : http://www.cardomain.com/ride/2955823/1 67 truck build: http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1 69 k10: http://67-72chevytrucks.com/vboard/s...d.php?t=389470 |
i'll take a stab since i will be swapping my 71 gmc over soon, but with air ride. i know that on my swb the trailing arm crossmember is there, but the brackets for the trailing arms are not. also, the the crossmember that the rear shocks are attached to on the leaf suspension is different. then theres the panhard bar, brackets, and hardware that have to be addressed. the rearend does not have the cast in mount (hole) for the panhard bar, but that is'nt a show stopper unless you want it stock looking. early classic or CPP can help with that issue. at the least you'll need a panhard setup, rearend with lower shock mounts, trailing arms and brackets, and the coils, bags or whatever...... this is what i know about swb trucks, i have no idea what you have if your is a lwb.
-02 avalanche (daily driver) -66 gto ragtop 389/400 (garage queen, hand-me-down from dad) -72 Tribute Trans Am (6.0LS/T56 6-speed) in progress -2003 YUKON (Wife's) -71 gmc swb fleet (current project, gonna shave everything, bags, stuff w/ 20's, gen III powertrain) -48 3100 SWB - 12/31/23 LONG TERM Project |
Next project: 1970 K10
Other than swapping parts from a coil truck (like mentioned above), one of the biggest things to address are the coil springs themselves.
The frame rails on the leaf truck are practically straight/parallel over the axle, where the coil spring frame bends out. The coil springs attach to the underside of the frame. (See pic) So when converting a leaf truck to coils, a bracket needs to be made to bolt/weld to the outside of the frame to give the coils something to attach to. I have seen these for sale (don't remember where), but they would be super easy to fab. Use ECE's super track bar. It mounts to the frame on the drivers side (will need the OEM bracket, or fab one) then to the right side trailing arm. You will need the trailing arms saddles off of a coil spring rearend. Or just find a complete coil spring rear end. Shock crossmember (upper), shock brackets off of a coil rearend (lower). Front trailing arm brackets. LWB, SWB, it's all the same back there.
Bob 1970 Chevy K10 LWB "Goldie" 350/TH350 next project!! 1981 Chevy C10 LWB 355/TH350 - My son's truck LS SWAP FORUM! Tons of LS swap info here! PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET! CLICK HERE FOR THE FAQ INDEX by KRUE |
thanks Glock i forgot about the upper coil mounts. i went back and looked at the frames and compared the 71 gmc to my 72 chevrolet with coils and the frames are exactly the same.
#6 | |
Compare your pic to mine, and you can see where the trailing arm brackets go. The holes closer to the hole for the driveshaft are for the carrier bearing bracket to mount to.
Bob 1970 Chevy K10 LWB "Goldie" 350/TH350 next project!! 1981 Chevy C10 LWB 355/TH350 - My son's truck LS SWAP FORUM! Tons of LS swap info here! PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET! CLICK HERE FOR THE FAQ INDEX by KRUE Last edited by glock35ipsc; 06-23-2009 at 05:34 PM. |
#8 | |
The leaf frame did have some structural 'beads' in the steel around the spring hanger areas that the coil frames don't have.
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 06-23-2009 at 07:28 PM. |
So what would i need if my crossmember will work?
The frames are the same except for a few reinforcing dipples that are stamped right where the leafs supports go..I just finished doing this swap , and got a lot of help from everybody here.I found the best way was to do it with the box off , and have a coil truck handy for all the brackets you need...and for measuring all the bolt hole locations...i'll try to resize some pics of how mine came out.
#11 | |
i love pics so here i go.....
more
hope i don't over load the server.... hope these help
#15 |
Now thats step by step great dude!! thanks
#16 |
And what are you guys doing with the old leaf springs? There are some people who do the exact opposite swap. Brackets, hangers and such are hard to come by. We do have a sale forum here. That's all I'm say'n.
(Mine was born with leaves)
'70 GMC C1500 LWB Power disc brakes. WooHoo! Posi 6 Lug Dana 60 |
#17 | |
powerbench - Great pics!!
#18 |
I parted a LWB GMC many years ago and it had leafs and the trailing arm crossmember sans the brackets. It does have the carrier bearing support bracket. My question is that I can see the two larger holes to the outside have the parking brake cables running through it, what are the other two holes of the same size for? I plan to run my exhaust through there on the blazer. I think I can get by with leaving the brake cable holes but not the other two. Chad |
#19 | |
#20 |
So all i need are trailing arms, coil rearend, and crossmembers that i need? I think i can get a whole coil spring truck for about 200 bucks.
