Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 06-25-2009, 10:56 PM   #1
SCOTI
SCOTI's Avatar
Re: 76cc sbc head
I have a DCR file/program that calculates everything out so I'm not using any manufacturers specs specifically. I really don't want to run that cam & piston combo for reliabilty & torque..... It's what was already there & I was planning to change it but now I'm considering other options.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
SCOTI is online now   Reply With Quote
Old 06-27-2009, 04:13 PM   #2
6t9ls1
Re: 76cc sbc head
hey man for what its worth i was building a Gen 1 406 and jumped the gun before consulting anybody and bought a set of trick flow 195's with 76cc chambers only too be told by my machinest that it would be a total dawg because those runners would more or less choke the motor. Engine specs were as follows: stock block .30 over kieth black pistons at 10.8-1 comp, comp solid roller .552 int. .564 exh. 24?-25? dur. on a 110, pete jackson gear drive, harland sharp roller rockers. I took his advice and switched to a 350 block bored .40 with kieth black pistons same compression.
As far as heads the AFR are very good pieces. You may want to check out Total Engine Airflow. They take aftermarket and stock heads and rework them. They do killer work.
1969 GMC Long bed 2wd-Work in Progress
1987 GMC Short bed 2wd- 283(lunati voodoo cam, aluminum intake, edelbrock 600 carb, headers, msd ignition), 700r4 w/2800 stall, 4.88 limited slip, more to come
6t9ls1 is offline   Reply With Quote
Old 06-29-2009, 06:09 AM   #3
Bowtie67
Bowtie67's Avatar
Re: 76cc sbc head
As of the past few years I have only been running roller cams and probally wont be going back to the flat tappets due to todays oils, and the power to be had by roller cams. There are some really nice roller cams that I can think of right off hand for your combo.
Comp 224/230@.050 276/282 HR the have this cam with a 110LC and a 112LC the 112 is a marine cam, I ran the marine cam in a 413 with 10.5cr, lots of great tourque, fun not real radical, good sounding cam.
If your wanting something radical try running the crower I listed above, the cam is a beast massive tourque, you will be rattling windows and melting tires. I was going to have them grind me this cam but put it on a 113LC, but after gettimng jerked around for an hour on the phone I called Lunati.
I havent ran this cam but was very tempted in my 427, comp cams EFI xtreme h/roller the specs @.050 230/236 on a 114LC and uses 1.6 rockers (this could be considered nice a sleeper cam and because of its LC of 114 would make a very nice cruzeable cam) Check with comp to see if this cam would have any type of lope to it, if it does it probally not much.
1967 C10 - SWBSS Pro Street 427sbc, 700R4 & 4.10 Gears
1948 Chevy FleetMaster Coupe, LS1, (almost done)
1950 Chevy StyleLine Coupe 250/6 3x2 Dueces
2009 Toyota Tundra
1996 Harley RoadKing
"I maybe getting old, but I can still burn rubber with the best of them"
Bowtie67 is offline   Reply With Quote
