Alternator, Left or Right Mount?
Greetings to All,
My 72' has the alternator and p/s mounted on the LH side of the engine. It does not have a/c and it is my understanding the the power steering was added. I have noticed that on some posts the alternator is mounted on the RH side of the engine. Which is correct for a 72'? Thanks MrBlue |
Old member
Re: Alternator, Left or Right Mount?
Power steering and alternator should be on left side of motor.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
its all about the +6 inches
that is correct... and left, meaning drivers side.
The passenger side is 73 and up truck, or 70 and up car design |
