Resistance is Futile
Re: Lower Control Arms and Control Arm Shafts?
Soak them with penetrating oil. They could be rusted on there pretty well. I had to use a 3/4'' drive rachet. The caps are definitely threaded on. Once they break loose they will come off and you will be able to snake the cross shaft out of the a-arm.
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash 64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban 66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852 STRENGTH/DETERMINATION/MERCILESS/FOREVER .......posted via stationary device |
I can turn the shaft. I cannot turn the caps. It's all coated with POR15 if that makes any difference. But the caps do not want to break loose. I figured if I cut a space out of the middle of the shafts, I could screw the halves out and then know the caps out. But I figure there's got to be an easier way.
"I never apologize. I'm sorry, but that's just the way I am." - Homer J. Simpson 1955 2nd Series Chevy "King Of Trucks" |
1 thing at a time is progress.
If yours look like this, they definately screw out. I know you said they have POR15 on it so you might not want to use heat, but it is an option. Just warm the A arm up a little. Just my .02
Alan
Philippians 2:14-16 |
60-66 Nut
Those are usually a real B***h to get loose. It may require a 3/4 drive socket....1 5/8" IIRC, 3/4 breaker bar (or 3/4 impact) and some heat. Be careful as to not get the control are too hot or you could weaken it. You could try as you mentioned and cut the shaft out, but then you still have to get the caps out of the control arm. Either way you're most likely going to have to touch up the POR
I cut a link out of the shaft so I could screw out what was left of the shaft. But the caps will not budge from the control arm. I'm working on cutting the other shaft out. I don't know how I'm going to get the caps out though.
#6 | |
60-66 Nut
![]() The caps are threaded into the control arms as well as onto the shafts.
#7 | |
![]() I guess I'll get them in a vise with a big ratchet and a big breaker bar. It's a good thing you posted before I took them to my buddy's to press them out. ![]()
