Old 06-29-2009, 02:43 PM   #1
Cohl
Cohl's Avatar
Dirct to metal fill primer
hello all, does anybody know of a direct to metal high build primer that comes in something other than grey? I'm gonna be driving around for a while like this so I was looking for red or something less boring than grey. Thanks in advance for any help.
Cohl is offline   Reply With Quote
Old 06-29-2009, 02:55 PM   #2
losangelesk5
Re: Dirct to metal fill primer
You should be able to get your grey primer tinted
losangelesk5 is offline   Reply With Quote
Old 06-29-2009, 02:58 PM   #3
teamradrz1
teamradrz1's Avatar
we used green on my sons Camaro if you are going directly to metal you should use etching primer.
1971 Chevy Blazer CST 4X4
2012 Camaro 2SS/RS
2007 Avalanche 4X4
teamradrz1 is offline   Reply With Quote
Old 06-29-2009, 03:06 PM   #4
turp mcspray
turp mcspray's Avatar
PPG has or had a yummy mauve color.
Turp Mcspray
New life for an old 2wd, farm blazer
http://67-72chevytrucks.com/vboard/s...d.php?t=505987
My Blazer build http://67-72chevytrucks.com/vboard/s...d.php?t=342299
turp mcspray is offline   Reply With Quote
Old 06-29-2009, 09:59 PM   #5
ChevyFan24
Junior Member
I am not sure there is a "high build" primer that is direct to metal. I would check with a local paint supply store. Several high build primers can be tinted. I would use an etching primer first and then a primer filler but they are not made to with stand the weather without top coat.
1967 Camaro (in pieces)
1972 Chevrolet K/5 Blazer
1969 Chevrolet K/5 Blazer
2000 Chevrolet K2500 Crew Cab 454
1999 Chevrolet Blazer
2008 Polaris Ranger XP Orange Crush
ChevyFan24 is offline   Reply With Quote
Old 06-30-2009, 05:53 AM   #6
vtblazer
vtblazer's Avatar
Whatever color you find, if your going to run it for awhile without a top coat, make the final primer coat an epoxy primer, the others will absorb water.
vtblazer is offline   Reply With Quote
