06-28-2009, 06:16 PM | #1 |
PROJECT 7DEUCE
Need some starter help....
The starter in my truck seems to have died.. I took it out ran to shucks and they said it tested fine? So I run back home throw her back in the truck and I get nothing? No click click no poof up in flames nothing. So I grab my handy screw driver and try to jump it on the solionod....nothing? However when I turn the ing key to the crank position the volt gauge drops down to 10 volts... Soooo anyone have any ideas here cause I also went to vato zone and they said it was good????????
GO BIG GREEN GO DUCKS MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
06-28-2009, 06:20 PM | #2 |
Re: Need some started help....
did you ever think to check and see if your battery was charged or good?
06-28-2009, 06:41 PM | #3 |
I am a Referee of life.
Sounds like a bad cell in the battery to me.If it doesn't click or try to turn over the battery may be shorting when it has a draw applied.Just a thought.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" |
06-28-2009, 06:45 PM | #4 |
PROJECT 7DEUCE
I have the battery on the charger right as soon as the wife gets home with the blazer ill swap batterys.... Btw the battery is less than 3 months old from sears....
06-28-2009, 07:08 PM | #5 |
20' Daredevil (Ret)
Two places tested it & said it was good.... Bad battery sounds reasonable; even new ones can fail. If not that, maybe a bad cable or connection? I *think* poor connections can cause excessive current draw, which can result in a lower voltage reading.
- Mike - 1972 K20 LWB 350/350/205 RIP El Jay |
06-28-2009, 07:43 PM | #6 |
PROJECT 7DEUCE
Battery is now fully charged and same thing .. I cant even jump it with the screw driver.... and yes still waiting on the little lady to get home to swap batterys...
06-28-2009, 07:51 PM | #7 |
Try running a jumper from the negative side of the battery to the starter housing to make sure you have a good ground.Also did they check the solenoid with the starter.
69 Chevy 4x4 383 Power |
06-28-2009, 08:04 PM | #8 |
PROJECT 7DEUCE
I swapped the solinoid as I thought that was what was wrong at first... I also ran a wire from the negitive battery post to the starter... same thing?
06-28-2009, 08:20 PM | #9 |
If you tried all this it has to be in the wiring. I would take the starter out and hook it to a battery with jumper cables then run a wire from the ign side of the starter to pos and see if it engages be careful as it will want to jump around. Make sure you are hooking the ign wire to the right post.
06-28-2009, 09:22 PM | #10 |
People know me
Bad battery cable/connection
1972 k/5 blazer CST 4X4 Crate 350, th350/205, dana44with trac-loc/14 bolt with detroit locker, 4 wheel discs 4.56s, 8" suspension lift using 73-87springs, 1" zerorate custom front crossmember, HAD CV drivelines and driveshaft e-brake, full cage, PRP seats, Full autometer gauges, 38x14.5x16 Toyo M/Ts, 16x10 Polished aluminum rockcrusher wheels 1967 longbox 4x4, Strong 400/400/208, 44/12bolt 4.10s, 6" lift, 35" Toyo M/Ts on corvette rally wheels |
06-28-2009, 09:37 PM | #11 |
dazed and confused
i had a bad ground one time that caused the same thing. i ran a ground wire from the block to the frame and then from the block to neg. side of the battery. it seemed to fix it.
members met: redbaron69, billsbowtie,nc67 |
06-28-2009, 09:42 PM | #12 |
Brad 72 Blazer CST 350/350/205 |
06-28-2009, 10:19 PM | #13 |
PROJECT 7DEUCE
Re: Need some starter help....
Ok so I pulled the starter from the truck agian...... I took my battery charger and hooked the red to the batt lug on the solonoid and the black wire on one of the front starter bolts that goes through the case. I took a piece of wire with an eyelet on it and hooked it to the s side of the solonoid and touched the stripped end of said wire to the positive battery lug on the soloniod....and ....................... guess what happend...... nothing so??? do I need jumper cables and try this with a battery? stummmped.........
06-28-2009, 10:31 PM | #14 |
Junior Member
I have never had much luck using a battery charger to test a starter.
If I remember right it takes between 100 and 150 amps to kick a starter. It really sounds like you have a wiring or connection problem. Not long ago I was at a gas station filling up, when I went to start the truck-nothing. It turned out there was some corrosion on the battery terminals. The corrosion was not real visible, but when I cleaned the battery terminals and connections and hooked it back up it started without a problem. Danny
'67 Chevy C-20 short stepper - build complete, 454/SM-465. '75 C-30 Single Cab DRW-350 small block/NP-435. '77 GMC-6500 Dump Truck, 427 Tall Deck. '92 GMC K-3500 Duallie, 454/4L80E. |
06-28-2009, 10:38 PM | #15 | |
The battery charger does not have enough cranking amps to really spin the starter but it should turn it with no load.
06-28-2009, 10:43 PM | #16 |
PROJECT 7DEUCE
I also tried the jumper cable idea and nothing but...... I did notice the solinoid was getting warm....
06-28-2009, 10:47 PM | #17 |
I think you may have a bad solenoid. I just went out to the garage and took one of my old starters and hooked to the charger and it spun right over. had to put the charger on manual
06-28-2009, 11:08 PM | #18 |
PROJECT 7DEUCE
Ok so I hooked the charger up to it and it wanted to turn but was really (drawing some power makin mmmmmmmmmm noise)it very very slowly turned then stopped..... My guess is that the starter is a p.o.s. but I dont under stand how vato zone and smucks got it to test fine?
06-28-2009, 11:36 PM | #19 |
Size Matters
A volt meter will tell you what you need to know. Put the red lead on the starter lug...the one after the solenoid and the black one in the center of the neg. post of the battery. Hit the key. If you don't get 12 volts, you have a voltage drop somewhere. Start backing up the circuit witht the red lead. First the other side of the solenoid, then the outside of the pos. terminal. If you do see 12 volts on the first measurement, start moving your ground lead. First the outside of the neg. terminal then the chassis, then the engine block. If you see 12 volts from the case of the starter to the starter lug of the starter...go buy a starter.
"Reading the owners manual is only for quitters." Jason Harper, Bloomberg News. ...WOOOO HOOOO!!!! Last edited by Longhorn321; 06-28-2009 at 11:39 PM. |
06-29-2009, 10:51 PM | #20 |
PROJECT 7DEUCE
Well guys I took it to a little guy shop here in town and the starter is junk.... So I bought a new mini starter for $100 bones.. Thanks for all the help and knowledge you guys have given me..
06-30-2009, 12:42 AM | #21 |
20' Daredevil (Ret)
Glad ya got it working, Luke. Better luck with the new one!
06-30-2009, 08:03 AM | #22 |
Size Matters
There is a shop just for little guys? J/K Glad you got it going.
"Reading the owners manual is only for quitters." Jason Harper, Bloomberg News. ...WOOOO HOOOO!!!! |
