Originally Posted by Pyrotechnic
Use a voltmeter on the + side of the coil to check for voltage after the key is turned off.
OK, here's what happened...
on the aftermarket started the posts are closer together one of the leads wasn't tightened down enough and twisted to touch a post which caused the power to remain constant to the coil......fried the new and old coil.
replaced the coil after the fix and tested the coil on the + side with key off like Pyrotechnic said and now it's working fine.
Thanks guys!
Friday she goes in for the rebuild
