Old 06-30-2009, 09:48 PM   #1
1972CST
1972CST's Avatar
D44 carrier ?
Can I put a ring ,pinion and carrier out of a 3/4 ton D44 into a 1/2 ton D44?
1972CST is offline   Reply With Quote
Old 07-01-2009, 12:09 AM   #2
rcflyer1234
rcflyer1234's Avatar
Re: D44 carrier ?
I believe that you can yes.
rcflyer1234 is offline   Reply With Quote
Old 07-01-2009, 07:30 PM   #3
LONGHAIR
Re: D44 carrier ?
They are only different from the knuckle out-ward.....but, it is not as simple as unbolting parts from one housing and bolting them back into another. There is a lot of precision measuring and fitting involved, plus some very specialized tools...and it's even harder with "used" gears. It helps if the person setting them up is also the one who takes apart the donor axle, but that will probably cost you more money though.
I always recommend seeking a professional for ring/pinion set ups. It's just not a job for the average guy. Most people will only ever need to do this once and it's just not worth the investment of one time. Pay a pro and get a warranty....but don't be surprized if they won't do used gears.
You can review the site's rules here.
Originally Posted by Longhorn Man View Post
As for reading directions...
The directions are nothing but another man's opinion.
Learn from the mistakes of others, you won't live long enough to make them all yourself...
Bad planning on your part does not necessarily constitute an instant emergency on my part....
The great thing about being a pessimist is that you are either pleasantly surprised or right.
LONGHAIR is offline   Reply With Quote
Old 07-01-2009, 09:44 PM   #4
1972CST
1972CST's Avatar
Re: D44 carrier ?
Thanks for the info Longhair. I have set up a new ring and pinion in a Fud 9in. and its still doing fine. I didnt know a used gearset would be harder to set up. I found a good used 4.10 ring and pinion w/ the correct carrier for $100.
This is alot cheaper then a new set plus I need the carrier for the lower gears.
