Too much oil pressure?
Did a lot of work on the old girl this week. On my neighbors recomendation I installed a high volume oil pump while I had my pan off. Now I have too much oil pressure. Is this bad? What could happen with too much press and how likley is it to happen. It is at the top of the guage at idle
Brad 72 Blazer CST 350/350/205 ![]() ![]() |
huh?
![]() Join Date: May 2000
Re: Too much oil pressure?
I think with a high volume pump and a stock pan you might suck the pan dry if you really get on it hard. I might be wrong, but I'm pretty sure I've heard that before.
Someday when I'm lonely, Wishing you weren't so far away, Then I will remember Things we said today. RIP El Jay |
Ide start by getting a oil pressure gauge thats full sweep and seeing exactly what numbers your hitting .
My 400 sb ran a high volume pump and stock pan and never had a that problem but 50lb pressure was about as low as it went and it would idle at around 75lb until warm I always kept it under 82 lbs. ![]() |
![]() Join Date: May 2009
Just a thought (rare, I know), don't those high volume pumps come with 2 different pressure springs? (wait..... that's a question)
My goal in life is to be as good a person as my dog already thinks I am - Unknown |
Old Skool Club
![]() Join Date: Jun 2001
Okay, for each 1000 RPM's, you need 10 lbs of pressure. Now, my school bus will be sitting at almost 0PSI at an idle. That is a worrisome thing, for me. However, I've been told that it has a high volume, low pressure oil pump. I reckon that's a good thing, because I have over 70K miles on it w/o any oiling problems.
Member Nr. 2770 '96 GMC Sportside; 4.3/SLT - Daily driven....constantly needs washed. '69 C-10 SWB; 350/TH400 - in limbo The older I get, the better I was. |
I can't see how with a high volume oil pump you would starve it on oil. All the oil is running thru the engine. Now if you were doing serious stock car stuff, or drag racing, then you would add a larger oil pan capacity. Just can't see anyone on the street doing damage with a high volume pump on a street machine even under extreme conditions.
'69 Chevy Long Fleet & '71 GMC Short Step & Project "ODD BALL" "You can wash a pig, soak it in most expensive perfume. In the end it is still just a pig." ODD BALL build thread http://67-72chevytrucks.com/vboard/s...d.php?t=478629" |
#7 | |
Big Red - Now its a SWB!
68 3/4 ton ![]() ![]() 41 3/4 ton ![]() 01 Tahoe LT 4WD (my daily driver)-Magnaflow Muffler, Rollin on 22's 02 Ford Mustang Convertable (Wife's Car)-Flowmaster 50, Clear corners, Intake, sittin on 18's |
So do I have anything to worry about. What oil press are you guys running? any problems?
I've been running a high pressure pump with a stock pan for two years now with no problems.
#10 | |
What kind of pressures are you getting?
