Fender repair............
Can anyone tell me where I can get a patch panel? Mine was ruined by battery acid rust, along with the radiator support.
See attached photos Last edited by Longhorn Man; 07-02-2009 at 07:50 PM. Reason: removed WTB |
Junior Member
![]() Join Date: Jun 2003
Re: Fender repair............
They make a patch panel for this. Check with any of the vendors that support the board.
Big Red - Now its a SWB!
this is a common issue, I have the same rust on mine (not quite as bad). you can get patch panels out of lmc or many others. good luck
68 3/4 ton ![]() ![]() 41 3/4 ton ![]() 01 Tahoe LT 4WD (my daily driver)-Magnaflow Muffler, Rollin on 22's 02 Ford Mustang Convertable (Wife's Car)-Flowmaster 50, Clear corners, Intake, sittin on 18's |
Thank you, which section do I look? I have been through the parts for sale section, where are the vendors listed?
LMC only has the back, I just checked my catologue.
member #16
![]() Join Date: Dec 1999
Wes at classic heartbeat has them.
http://www.classicheartbeat.com/cata...nder%20tip.htm http://www.classicheartbeat.com/Patch%20Panels.htm
john http://67-72chevytrucks.com/vboard/showgroups.php board vendors ![]() http://www.flickr.com/photos/1745471...7602865984234/ Last edited by john; 07-02-2009 at 12:15 PM. |
Excellent, thanks!!!!!!!!
I am a Referee of life.
You wont find a used one.If you do it will be attached to a fender and they will want to sell you the whole thing.That area is so prone to rusting i don't remember ever seeing one that was good unless the whole truck had been redone or was so cherry it was a true survivor.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" |
its all about the +6 inches
Please take a moment and look over the rules you agreed to upon joining the site.
http://67-72chevytrucks.com/vboard/a...nt.php?f=3&a=9 The reason you weren't able to post in the parts forum is becouse you are not a subscribed member. For subscribing info, http://67-72chevytrucks.com/vboard/a...t.php?f=3&a=17 I modified your post instead of deleting it all together. |
I have one that came with my project truck, It actually replaces the whole bottom of the fender. inner and out fender bucket.
*We could learn a lot from crayons... Some are sharp; some are pretty;and some are dull. Some have weird names; and all are different colours;but they all have to live in the same box. * You may be only one person in the world, But you may also be the world to one person. * Some mistakes are too much fun to only make once. Two rules in life. 1. Never sweat the small stuff! 2. Everything is small stuff! |
CAN'T FIX NOTHIN
I will give you a HEADS UP on the fender patch ,
THEY ARE TO SHORT , unless they have made a major change the patch is 1'' to 1'' & 1/2 short , I did mine by adding a piece of metal to it but it caused more bodywork to have to be done , A GREAT WAY I THOUGHT OF LATER IS AS FOLLOW's #1 ORDER TWO OF THEM ! #2 CUT THE TWO LEAVING EXTRA METAL #3 FIT THE EXTRA LONG PIECES TOGETHER AND YOU WILL ONLY HAVE ONE WELD SEAM this is the best and most effective way to do this ,, unless someone could tell WHOEVER IN THE CRAP IT IS THAT MAKES THEM TO SHORT ! THAT HEY BUDDY THE ARE TOO DANG SHORT ! ![]()
1967 C10 Shortbed Fleetside Small back glass 6 cyl 3spd on the tree 3.08 gears underdash AC Last edited by 19673ontree; 07-02-2009 at 11:01 PM. |
CAN'T FIX NOTHIN
here is a pic from when I was working on mine , you can see in the pic how much to short the fender patch was ,,
1967 C10 Shortbed Fleetside Small back glass 6 cyl 3spd on the tree 3.08 gears underdash AC |
#13 | |
![]() Join Date: Nov 2004
(They're true 67 fenders too!) ![]() They're the most rust free set of original fenders I've ever laid my eyes on. (And hells no they're NOT for sale!)
Jesse James 1967 C10 SWB Stepside: 350/700R4/3.73 1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc 1968 Pontiac Firebird: Project Fire Chicken! 2015 Silverado Double Cab 5.3L Z71 2001 Jeep Wrangler Sport 4.0L 5spd 2020 Chevrolet Equinox Premium 2.0L Turbo 2011 Mustang V6 ~ Wife's ride ![]() American Born, Country by the Grace of God ![]() 1967 CST Shop Truck Rebuild! My 1967 C-10 Build Thread My Vintage Air A/C Install Project "On a Dime" Trying my hand at Home Renovation! 1965 Mustang Modifications! Last edited by 67ChevyRedneck; 07-03-2009 at 12:05 AM. |
Wes has a write up on how to do this repair. Here is the link
http://www.classicheartbeat.com/fender_tip_repair.htm Hope it helps....eb |
#15 |
i did mine not to long ago, I did just like the article on GMC pauls web site
I also had to remove the back piece the curve was not correct,then i had to make a pie cut down the front to get the inside front edges to line up i am going to run a bumper this wont be seen.
Mike K Friend of Bill W Last edited by jd4300fel; 07-04-2009 at 11:08 AM. Reason: spelling |
