Old 07-05-2009, 09:05 PM   #1
Walts_restoration
Real Projects never die
Walts_restoration's Avatar
Rear Brake drums needed for a factory posi dana 44
Its a factory positrac 2wd half ton, and he says it needs to be offset a half inch to the inside to fit properly. Normal rears are supposedly straight up and down. Anybuddy have any info on the differences or places to find a new, correct rear drum? Any infro appreciated, thanks guys.
Ill put it this way, ive got a few lawn ornaments
My name tag says Ryan
KansasTwister On other forums
Walts_restoration is offline   Reply With Quote
Old 07-06-2009, 06:53 PM   #2
Walts_restoration
Re: Rear Brake drums needed for a factory posi dana 44
bump for today.
Old 07-06-2009, 11:58 PM   #3
Captainfab
60-66 Nut
I assume you've checked and the drums for the Dana 44 are different than the ones for the 12 bolt? I've never worked on a Dana 44 rear differential, but it wouldn't surprise me if the brakes were the same.
Old 07-07-2009, 05:53 AM   #4
aerotruk63
Check The Champ, Demonstrator
aerotruk63's Avatar
If you give me the year and model of the diff I can look it up for you.
Old 07-07-2009, 08:33 AM   #5
slorio
slorio's Avatar
Walt:
The GMC's used the Dana 44. Here is a summary of my search for brake drums for my 1966 GMC with 6 lugs.
I have two part numbers you can try for rear 6 lug brake drums. The first is a Wagner BD 60089. The second is Allsafe 2067 DGS.
I used the Allsafe from Autozone. It is for a later model (I think 67-72) truck with 4 wheel drive. It has fins on the outside unlike the original that is smooth. The only modification that I had to make was to drill the 6 lug holes from 1/2" to 9/16" so that the drum would fit on the shoulders on the rear lugs like the original. This drum had the right offset unlike the Chevy drums.
The Wagner was a number that I got from another member of the 6066gmcguy.org site. I haven't used that one, but was told it was a direct match to the original (a bit pricey, though is what I remember).
I hope this helps with those looking for rear 6 lug drums.
Regards,
Steve Lorio
New Orleans, LA
slorio is offline   Reply With Quote
