Old 07-05-2009, 09:03 PM   #1
Sicboy
Sicboy's Avatar
Bed Wood Thickness
I'm gonna have some local (oregon) wood milled for the bed of my '66. Any of y'all know the exact thickness the plank should be? What is the width of each board? Are there step-by-step instructions posted anywhere?
Cheers,
Gary
Sicboy is offline   Reply With Quote
Old 07-05-2009, 09:08 PM   #2
chevysbest92
chevysbest92's Avatar
Re: Bed Wood Thickness
msgross sent me this.
hope it helps
http://www.gmcpauls.com/47-72_BedWood_Info.htm
I wouldnt have it any other way...CHEVROLET!
ALL throttle, NO bottle!!!
Theres NO replacement for displacement
Current Rides 2006 Silverado1966 Chevy c101972 Chevy Nova
Previous Rides
2003 Silverado
1992 Silverado
chevysbest92 is offline   Reply With Quote
Old 07-05-2009, 10:09 PM   #3
Chevy Fleetside
Chevy Fleetside's Avatar
3/4" thick.
"A man and his truck, what a beautiful thing"
65 Short Fleetside BBC
65 Long Fleetside 283 3 on the tree for now.
my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536
Chevy Fleetside is offline   Reply With Quote
Old 07-05-2009, 10:24 PM   #4
Alan's Classic
1 thing at a time is progress.
Alan's Classic's Avatar
hope it helps
That's a great link.
Alan's Classic is offline   Reply With Quote
Old 07-05-2009, 10:52 PM   #5
chevysbest92
yes it is, i want to go ooutside the box and make all my boards the same sizes, itll look better IMO
Previous Rides
2003 Silverado
1992 Silverado
Old 07-05-2009, 11:16 PM   #6
Sicboy
Sicboy's Avatar
hope it helps
Thanks for the link.
Originally Posted by Chevy Fleetside View Post
3/4" thick.
Thanks.
Old 07-06-2009, 07:59 PM   #7
justbad
be very carefull about the thickness of your bed wood .if it is to thick your body lines wont match up,as far a making them the same width that would be a real job,i just finished putting a wood bed in my 66 and aligning the mounting holes and the space between the wood is a bear.my sugjestion is no matter what you put in prefit everything first before you put a finish on the wood
justbad is offline   Reply With Quote
Old 07-06-2009, 08:02 PM   #8
chevysbest92
thanks justbad, will do
Previous Rides
2003 Silverado
1992 Silverado
Old 07-06-2009, 08:08 PM   #9
justbad
here is the kit i bought from classic truck parts complete kit cost about $700
for polished stainless and oak
Old 07-06-2009, 08:14 PM   #10
chevysbest92
ouch, i already have the polishes stainless, im going to cut and varnish the wood myself, i have a woodshop here
Previous Rides
2003 Silverado
1992 Silverado
Old 07-06-2009, 09:47 PM   #11
Alan's Classic
Nice job
Old 07-06-2009, 10:19 PM   #12
justbad
about the wood you are going to use i would go for a hard pine instead of oak
pine gives a much better finish than oak and is also a much smoother one too.
in that pic there are 14 or 15 coats of clear and you can still see the grain above the clears surface i tryed to make it look like it had a piece of glass on top of it and thats the best i could do.use helmsman spar oil base clear it holds up better than anything you can buy .you can also use a water base stain there are a lot of realy cool colors in water base but a very limited amount in oil base
Old 07-06-2009, 11:17 PM   #13
Chevy Fleetside
The bed looks good in the picture.
If you want real good results. Wet the wood and let the grain rise and then sand it.
I personally like the grain in wood. I am a carpenter so I guess that is why. I was going to use White Oak as it has a tighter grain the Red Oak and will hold up better outdoors. I still don't know what I am going to do for bedwood so it is a good thing I am far from that at this time.
Old 07-07-2009, 12:03 AM   #14
Sicboy
Sicboy's Avatar
Thanks for the info. Like I said, I'll be using local Oregon lumber. We've got a variety up here in the PNW. I'm considering using madrone. I too like woodgrain...I'm a woodworker.
Old 07-07-2009, 06:44 AM   #15
justbad
i cant hammer a nail good luck
Old 07-07-2009, 12:23 PM   #16
apachedaddy
apachedaddy's Avatar
I'm sure most of the parts houses get there wood kits from MAR-K. I got all my bed parts from them and would recommend them to everyone. And if ya watch the parts forum you can catch some good sale's to boot.
apachedaddy is offline   Reply With Quote
Old 07-07-2009, 01:26 PM   #17
502tripower
502tripower's Avatar
I build these beds all the time and recommend using the factory specs shown on Paul's GMC site. For the best results on your finish it is best to use a good marine varnish sealer with UV protection first. I like Pettit and recommend three coats. This seals the wood so your varnish will now build. Then use a good Marine Varnish with UV protection. I like Epifanes Easy Flow. I also recommend using a bronze wool or wet sand between coats once you start with the varnish. The bronze wool will not rust like steel. I would not recommend using any kind of water base materials at all. They just do not hold up. Good Luck
1963' Chev Custom Cab 502, 67' 435hp 3X2 intake, 9" 4:30 Posi
1961 Impala SS 348/350 4-speed 3:70 Posi
1961 Bel-Air Bubble Top 283 Turboglide soon to have a 348 3X2 4-speed
1950 17' Fairliner twin cockpit barrel stern 312 Y block 1X1 intake Borg Warner 1:1 gear
1957 Fleetform 14' twin cockpit barrel stern 1969 BP-125 Merc
1949 Transitier 3-wheel forklift Crosley 4-Banger
98' FXD
2002 2500HD
502tripower is offline   Reply With Quote
