Old 07-07-2009, 06:16 PM   #1
rick0312
rick0312's Avatar
power steering install
hey all,
I tried to install my powersteering setup on my new gm crate. It seems as the bracket setup will not work with a 8in balancer. my previous motor had a 7 in balancer. Any of you guys run into this problem and what was the soluton?........thanks
rick
69 C10 LWB GM 350 crate motor, 3.73 rearend
rick0312 is offline   Reply With Quote
Old 07-07-2009, 06:59 PM   #2
john
member #16
john's Avatar
Re: power steering install
Does your new crate have a long water pump? If so you will need all the pulleys and brackets off of the old engine along with the short pump.
john is offline   Reply With Quote
Old 07-07-2009, 07:15 PM   #3
rick0312
rick0312's Avatar
no I have the short pump on the new motor. it seems that the 8 in balancer is interfering with the bottom pump bracket. I quess I could switch to a 7in balancer, but there should be a simpler solution.
Old 07-07-2009, 08:06 PM   #4
rick0312
rick0312's Avatar
is there a different bracket setup for use with a larger vibration damper? I would prefer to keep the larger damper installed.
Old 07-07-2009, 08:25 PM   #5
turp mcspray
turp mcspray's Avatar
You have a bracket for a small balancer. Just find the correct bracket for the large balancer. Shouldn't be too tough to do . Or you could buy a new bracket. If you want a new one and the truck catologs don't offer one go to Ground Up restoration parts. Find one for a 68 and older application with short water pump. I bought one there for my El Camino. Get the one listed for an L-79 327.They all had the large balancer with the short pump.
Turp Mcspray
New life for an old 2wd, farm blazer
http://67-72chevytrucks.com/vboard/s...d.php?t=505987
My Blazer build http://67-72chevytrucks.com/vboard/s...d.php?t=342299
turp mcspray is offline   Reply With Quote
Old 07-07-2009, 10:46 PM   #6
rick0312
rick0312's Avatar
thanks for the info Turp.....pulled a pic off of ground up website. does this look like the bracket i need........thanks for the help
