Old 07-08-2009, 11:24 AM   #1
Yellow76
Yellow76's Avatar
Problems lifting 2wd
I have a 76 chevy 1/2ton and i want to do a 4 inch spindle lift but i cant find one. So i have been looking and i found one for a 88 chevy will it fit on mine or can i do something different to get 4 inches of lift?
Yellow76 is offline   Reply With Quote
Old 07-08-2009, 12:46 PM   #2
Prerunner1982
Prerunner1982's Avatar
Re: Problems lifting 2wd
They do not currently make a spindle lift for pre 88 trucks... that I am aware of. AIM did in the past but quite some time back and I have never heard anything good about them anyways. There are coil lifts available with tubular control arms but a spindle lift is the BEST way to keep steering geometry.
I have heard/seen people use the 88-98 4" spindle on pre 88 trucks. It does involve swapping a couple ball joints and I believe lower control arms. I have never done it or see a write up about it specifically for lifting a 2wd.
Using the coils is ok.. it gets the lift but it puts the tie rods/ball joints a severe angles and also almost eliminates any down travel in the suspension. The design of the front suspension does not lend itself well to lifting.
here is a thread with some pictures... for "inspiration".
Jon
1982 Chevy Silverado 350/th350.... RETIRED
1993 Jeep XJ 2 door(Cherokee) 4wd 4.0ltr/AX-15 (5spd)/NP231
Oklahoma Roll Call
Prerunner1982 is offline   Reply With Quote
Old 07-08-2009, 01:11 PM   #3
konajoe
konajoe's Avatar
I'm not sure if this helps...
http://67-72chevytrucks.com/vboard/s...d.php?t=345881
05 1500 Crew Cab
79 K10 Scottsdale
71 K10/Custom
85 K30 CrewCab
72 Camaro
konajoe is offline   Reply With Quote
Old 07-08-2009, 01:56 PM   #4
Prerunner1982
In all my multi-tasking I forgot to post the link.
http://67-72chevytrucks.com/vboard/s...d.php?t=176272
Jon
Oklahoma Roll Call
Old 07-08-2009, 02:46 PM   #5
Mike_D
I ran a ball joint spacer and a moog 3/4 spring on the front of my 78 blazer. The set up yielded me 5" up and 5" down travel. I also had a simple shock hoop with with two shocks per side. The stock upper arms were tabed and they ran to the top on the hood
Mike_D is offline   Reply With Quote
Old 07-08-2009, 03:05 PM   #6
Prerunner1982
here is the problem with running lift coils.. Granted the truck pictured is sans engine, but it still demonstrates the problem when trying to get too much lift from a coil.
On my 82 I ran 1 ton front coils and could fit 32"s with a slight rub problem.
Jon
Oklahoma Roll Call
Old 07-08-2009, 03:08 PM   #7
Prerunner1982
Do you have any pictures of this set up?
Jon
Oklahoma Roll Call
Old 07-08-2009, 08:39 PM   #8
jrp267
I would like to put 4 inch spindles in my R30 but nothing exsists.
jrp267 is offline   Reply With Quote
Old 07-08-2009, 09:18 PM   #9
thebrown83
thebrown83's Avatar
check out this thread...
http://67-72chevytrucks.com/vboard/s...d.php?t=345479
thebrown83 is offline   Reply With Quote
Old 07-08-2009, 09:51 PM   #10
Yellow76
Yellow76's Avatar
If i got 4 inches of lift in the front could i fit 31/11.50 tires?
Old 07-08-2009, 10:42 PM   #11
74 C-30
Dually Pride
74 C-30's Avatar
my stock 2wd 1 ton fits 33, no rub
you can use 1 ton coils, but it'll ride rough as hell
ever think of a body lift?
If I have to explain, you wouldn't understand.
'74 Chevy C-30 350/4 speed/dually
'94 Ford Ranger
74 C-30 is offline   Reply With Quote
Old 07-08-2009, 10:50 PM   #12
flamingbig10
6.0 powered square
flamingbig10's Avatar
here a 3" body lift with stock worn coils on 32s
with hd coils
Aaron
1980 c-10 short bed lowered, cammed 6.0, 4l80e 3600 stall, smp tune, wilwoods, and flames best time so far best et 7.86 @87 on motor 7.57 90 on a 75 shot
Build http://67-72chevytrucks.com/vboard/s...d.php?t=283326
flamingbig10 is offline   Reply With Quote
Old 07-09-2009, 08:22 AM   #13
Prerunner1982
You dont need 4", just 1ton coils. My 82 ran 31"s with no rubbing issues.
My truck with 32"s..
Jon
Oklahoma Roll Call
Old 07-09-2009, 11:07 PM   #14
USSkoval
My old '79 2wd Blazer had a set of 32/11.5/15 on it. It was stock hight and no rubbing at all.
USSkoval is offline   Reply With Quote
Old 07-12-2009, 05:07 PM   #15
EHeki81
EHeki81's Avatar
If you look at my pics I run 33x12.5 with no rubbing, actually it looks 4 wheel drive now. I used 3" Fab tech and ball joint spacer and a 3" body lift. I drive it everyday no problems and isnt really that much of a stiffer ride. I put Kyb lifted shocks though.
EHeki81 is offline   Reply With Quote
Old 03-10-2010, 10:31 PM   #16
87 chevy silverado
i have a 87 chevy silverado all stock an got 31x10.50 an got good clearance
87 chevy silverado is offline   Reply With Quote
