07-08-2009, 05:03 PM | #1 |
6 lug disks?
I read on here in a post about a guy using 68 3/4 lower control arms with like 95 spindles and 6 lug rotors. Anyone else done this? has anyone that has done this driven the truck? I am thinking about changing the 68 8 lug GMC over to a coil spung rear 1/2 ton. I have a 95 light duty 3/4 ton out in the rest of my junk, so I have the rotors spindles tie rods[inner and outer] calipers and the other odds and ends. Thanks for your help. Jim
07-08-2009, 11:13 PM | #2 |
Re: 6 lug disks?
A bump in my quest for knowledge. Jim
07-12-2009, 04:00 PM | #3 |
if they can make it so can I!
Re: 6 lug disks?
this is how i done mine...you use 71-72 3/4 ton lower a-arms put the newer year model 3/4 lower ball joint in and change out the upper ball joints with the newer year model...hope this helps
07-12-2009, 04:24 PM | #4 |
Re: 6 lug disks?
That helps a bunch. That how I understood it to go. Whrn I changed my 70 over to disks I used a 72 for every thing, mainlt because I didn't have any 3/4 ton lower control arms. Now I am working on this 68 GMC 2500 and think it will ride better if I change it to half ton with the coil sprung rear. That will leave me with the 3/4 lca's to start this. Thanks, Jim
07-12-2009, 04:50 PM | #5 |
mini truck racer
Re: 6 lug disks?
I have done this swap . I used 68 3/4 ton lower arms . 90 light duty spindles and 6 lug 1.25" rotors ( or the thicker ones ) and a 88-95 1/2 ton upper ball joint . Takes a certain outer tie rod and a certain inner tie rod to make it work . This info is in the FAQ section somewhere .
Mine aligned good and drove good . If you do this swap you can go 5 lug later just buy changing the rotor .
1949 5-window 1969 Camaro 1976 Chevy Luv yellow 1978 Chevy Luv Blue 1976 Chevy Luv Black 1979 Firebird Flooded in Harvey 1999 F350 Dually 2005 GMC Sierra 4.8 RCSB 2014 Explorer (wifes) My build :http://67-72chevytrucks.com/vboard/s...d.php?t=399148 Build #2: http://67-72chevytrucks.com/vboard/s...d.php?t=653583 |
07-12-2009, 06:33 PM | #6 |
Re: 6 lug disks?
Thank guys.I think I will change from 8 lug 3/4 ton leaf spring rear to 1/2 ton coil spring rear and do the 6 lug disks in front. By that I mean that I have complete rolling 70 lwb frame from when I changed my 70 to swb with 5lug suspension. I am caught up in the shop right now ,so it seems to be the perfect time to do this change. I am also using the bed off my 70 on the 68 it has a good metal floor. Jim
