Old 07-13-2009, 08:37 PM   #1
Wildstreak
"something witty here"
Wildstreak's Avatar
disassemble help needed
Just getting ready to do some body work on a project and its my first time dissembling these trucks....well anything for that matter. Before i damage anything I figured i would ask everyone on here. I couldnt find any info on how to remove the steering shaft. I've enclose a pick to show the shaft so there is no confusion(I'm not sure what its really called, once again I am a total beginner). How do I take this out?
Thanks for the help in advance
57 chevy 4x4
70 swb fleetside 4x4
68 burb 2wd:
71 burb 2wd: 350 4spd
71 lwb fleetside 4x4: 350/sm465/205/3.07 eaton posi rear
72 lwb fleetside Cheyenne 454/th400
1991 GMC V3500 CC 4x4
Wildstreak is offline   Reply With Quote
Old 07-13-2009, 09:03 PM   #2
mr48chev
mr48chev's Avatar
Re: disassemble help needed
The easiest way for me is to take the two nuts off the bolts going through the rag joint at the bottom of the shaft and then take the bolt out at the top. That bolt will have a flat on one side that goes against the shaft
Old 07-13-2009, 09:17 PM   #3
mr48chev
mr48chev's Avatar
Once you have the bolt out of the top and the bottom end swung away from the rag joint the shaft should slide off. It may need a bit of persuasion from a hammer though.
Old 07-13-2009, 09:48 PM   #4
Wildstreak
Wildstreak's Avatar
I had removed the nuts on the rag join then undid this bolt but the shaft doesnt wanna move side to side so that I can slide it out, I feel like Im gonna break something if I push it to the side or pull it up.
57 chevy 4x4
68 burb 2wd:
