07-10-2009, 08:26 AM | #1 |
Tot Roddin'
Rivet Removal for the DIY'r
How have you guys removed the factory rivets from the frame?
I know most have air tools, and it's a simple process, but how about those without air tools. Is it possible? How do you "punch" the rivet out after you have removed the head? Thanks in advance!
-Nate 1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6) 1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior) 2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package) |
07-10-2009, 08:47 AM | #2 | |
The Older Generation
Re: Rivet Removal for the DIY'r
Nate, Here is a recent thread on the subject... http://67-72chevytrucks.com/vboard/s...d.php?t=351442 LockDoc
07-10-2009, 08:54 AM | #3 | |||
Union Electrician
hit a center punch or cold chisel with a hammer to knock it out
69 Custom-10 SWB FLEETSIDE 350/350 TH Dropped 3.5/5.5" Help support the board->HERE Board vendors -> Vendors list Zip:40272 Big Sandy Survivor... Quote:
07-10-2009, 10:24 AM | #4 |
BFH with a Big ole punch, with a big ole boy swinging it I Imagine, soak it down with some PB blaster first, a little heat wouldnt hurt either, I like to x them with the die grinder and air chisel em if ya have air...
"You can put lipstick on a pig, sure it's pretty pig, but it's still just a PIG... 71 LWB Last edited by UltraBlue71; 07-10-2009 at 10:28 AM. |
07-10-2009, 11:03 AM | #5 |
I just ground mine down with a 4" electric grinder flush with the frame and then smacked them with a hammer and punch.
A computer once beat me at chess, but it was no match for me at kick boxing. Duct tape is like the force. It has a light side, a dark side, and it holds the world together. |
07-10-2009, 11:11 AM | #6 |
Recovering 67-72 Addict
x2
68 Short Fleet 4x4; 427; BTO Level 3 700R4; NP205; Dana 60 front and rear; 4" lift with 35's; Disc brakes; AGR variable ratio steering; factory bucket seats; factory tach and tilt. "Friends call me cruzer cuz I like fast cars and fast women" |
07-10-2009, 02:13 PM | #7 |
Couple members in the thread LockDoc pasted mentioned a drill. I've done the same and it worked well.
07-10-2009, 05:35 PM | #8 |
Cold Chisel and a Big A** Hammer
1969 Short Stepside 1969 4 WD Suburban 1970 1 Ton Dually....Misfit oh, and a 2001 HD 2500, 8.1 Allison Shortbed 4 Door |
07-10-2009, 05:58 PM | #9 |
07-10-2009, 07:06 PM | #10 |
Work around with a hammer and quality chisle(mine is 3/4 wide) just to loosen any binding caused from rust.
I have done it two ways: Cut an x on the head of the rivet w/ a cutoff wheel, then work around with the chisle followed with a center punch to hammer through. Grind through half the depth of the rivet head. Work around with a chisle, you will start to notice the head mushrooming up. Run the grinder again and repeat the process. The second way of doing it will limit any grinding marks on the frame. After nocking the head off on one side, and the rivet still wont budge, use the hammer and chisle on the opposite side just to break it free. Double up on gloves. How many do you have to remove? Last edited by Kayotic; 07-10-2009 at 07:06 PM. |
07-10-2009, 07:13 PM | #11 |
67-72 parts collector,…
Cut-off wheel, grinder, punch, hammer.
Nate,... you get to do the next set of rivets!
07-10-2009, 08:22 PM | #12 |
Nate, whatever you do be sure to post a full length video!
I'm just wanting to see some scraped knuckles!!
-Scott- |
07-10-2009, 08:40 PM | #13 |
Nates been very busy today. He didn't have time to take any videos.
I'm sure he will post pics of his progress,...
07-10-2009, 09:08 PM | #14 |
Trucks N Tranzams
I drill the center out and tap it with a hammer and chisel.
Don '68 Chevy LB 383 TH400/GV/373 posi '56 Chevy 4WD SWB '64 Chevy short stepside '79 Trans Am 455/TH2004R/12blt/4whldisc 95 Kia (Wifes car) 2002 S-10 extended cab pickup "God punishes small sins immediately" |
07-11-2009, 06:36 AM | #15 |
Tot Roddin'
Guy's I can't thank you enough for the info!
I did have a little assistance... well a lot of assistance yesterday afternoon. I will try to get some pics up asap.
07-11-2009, 09:57 AM | #16 |
Hollister Road Co.
I drill the center of the rivet with a 1/4" or 3/8" bit to about 80% of the rivet depth. Chisel off the head and drive out the rivet. This way the rivet colapses inward and always comes out. It takes a litte more drill time but far less hammer and chisel time.
07-11-2009, 01:19 PM | #17 |
I just did some yesterday with a sharp wedge and a hammer. Jus knock the mess out of it and dont hit your finger. lol And knock the rest out with a punch.
07-11-2009, 02:20 PM | #18 |
07-14-2009, 09:09 PM | #19 |
Tot Roddin'
This was easier than I had expected.... here's how we did it:
- Break out the grinder with a cutting wheel, and cut the rivet head down almost to the frame. - Next break out the grinder and finish getting the rivet head down to the frame (you will begin to see the round dia. of the rivet itself) - Break out the hammer and punch and finish the job - After the rivet is out, smooth any gashes/cuts in the frame - Shoot with a coat of paint/rust preventer Plain and simple... it took me about 4-5 minutes for the first rivet, and then about 2-3 for the second. I'm looking for another frame to work on now. Thanks again guys!
07-14-2009, 09:19 PM | #20 |
i've knocked out 15+ rivets the last few days. had i known, i would of waited and brought my frame to you....wait i do have some more rivets to get out. i started the drill bit method and then gave up and just grinded and beat the heck out of these silly rivets
07-14-2009, 09:25 PM | #21 |
Tot Roddin'
Sorry to hear about that Tim!
I would be more than happy to remove them for you. Trust me, the cut, grind, hammer, smooth process has to be the easiest/cleanest way I've seen so far. However, I don't have an air compressor at my house, only at the farm, so I know there are easier ways. Bring it on down and I will finish her up for you.
07-14-2009, 09:49 PM | #22 |
thanks!!! i'm going to post some pictures of my work in progress here in a few days, i know one thing, wear glasses and gloves...
07-14-2009, 11:24 PM | #23 | |
I had a V-8
The nice thing about this method is it leaves you with a perfect hole and no scarring around it.
1972 K20 Suburban, 5.9L Cummins, Banks Power Pack, NV4500HD, NP205, H.A.D., D60/14FF ARB Link To Build: HERE. |
07-15-2009, 01:10 AM | #24 | |
Big Red - Now its a SWB!
68 3/4 ton (Project)-350 Small Block, .030 over, 10:1 comp, 3998993 heads, C3BX edelbrock intake, comp cams XE268, Holley 670 SA, long tube headers, dual flow 40's, E-fan, Alum rad, currently under the knife getting shortened and bagged build thread 41 3/4 ton (wife's)-flatbed, fully restored to original 01 Tahoe LT 4WD (my daily driver)-Magnaflow Muffler, Rollin on 22's 02 Ford Mustang Convertable (Wife's Car)-Flowmaster 50, Clear corners, Intake, sittin on 18's |
