Speedometer?'s
I pulled my speedo to reset it and when I got it reset to zero's the first two numbers of it spin freely. The small retaining bar doesn't go completly through the retainers of all the tumblers. There doesn't seem to be any damage to it. Any suggestions?
Re: Speedometer?'s
you broke off that little paper holder thing.. same thing happened to mine... they are very fragile..
1972 C-10...402/400..flowmaster 40 series 1967 Mustang 347 stroker/C-4 1966 Mustang 289/3-speed 2013 Mustang V6/6speed w/300 ponies I may be 23, but i sure do knows 67-72s are sexy! Its not MPG its smiles per gallon! build started 11/25/08 build thread: http://67-72chevytrucks.com/vboard/s....php?p=2993796 |
Re: Speedometer?'s
Do I need to buy a new one, or can this one be fixed?
Restoration Virgin!
Re: Speedometer?'s
I did this awhile ago....check this thread out....http://67-72chevytrucks.com/vboard/s...d.php?t=321688
Hope it helps!
Geoff with a G 1968 Chevy C10 SWB The Mistress 1972 Custom Deluxe C20 Suburban A Suburban Named Isabella 1966 Ford Mustang Mama's High School Graduation Present |
Active Member
![]() Join Date: Jul 2007
Re: Speedometer?'s
FYI: Be sure and read the last post in the thread posted by gcburdic.
Plastic in bottles are purposefully made to deteriorate and break apart in the sun and heat to help decomposing in land fills. |
Re: Speedometer?'s
Thanks. Once again this is exactly what I needed.
