07-13-2009, 09:27 PM | #1 |
Best rear suspension AIR RIDE?
Which setup would be the best for ride/performance. I will be using a ford 9 inch rear end. This will be installed on a 71 cheyenne. Has anyone use either of these kits. Any feedback or pictures would be great. Thanks Dbrasco
07-13-2009, 10:51 PM | #2 | |
Re: Best rear suspension AIR RIDE?
The "Rear Strong Arm kit" is designed to be used with the 12 bolt rear end, and the panhard bar mount would need to be modified for your 9 inch. The second pic is more of a universal type kit. Either one might be a good option. What are you looking to achieve? How low are you wanting to go?
www.PorterbuiltFabrication.com Phone: 480-297-2621 E-mail: sales@pbfab.com Find us on FaceBook under Porterbuilt Fabrication Specializing in Chassis and Suspension Components for your Classic Chevrolet Truck. We offer components from the following manufacturers: Porterbuilt Accuair Ridetech (Air Ride Technologies) Air Lift Wilwood Intro Unisteer ECE Gotta Show Air Lift Borgeson CPP Supporting this forum since 2003! |
07-14-2009, 01:11 AM | #3 |
I'm not looking to lay the frame on the ground. I like the ride height of the green truck that air ride tech has. I did'nt know which would be a better ride. The one with the bags in front or behind the rear end. I want something thats going to hold up with some horsepower. Porterbuilt what do you recomend for the back with a 9 inch? Do you perfer the 9 inch over the 12 bolt? Thanks Dbrasco
07-14-2009, 01:18 AM | #4 | |
If you're plan on putting down some good power, the 9 inch is a great choice. I am also a fan of the parallel four-link with long panhard bar. As for the sleeved bag vs. the trailing arms... they both ride nice. We installed the triangulated four-link kit and shockwaves you posted up, on a 66 a while back, and the truck rides and handels excellent.
07-14-2009, 01:47 AM | #5 |
VA72C10
Of course, Porterbuilt offers more options than just ART for the front and rear to lay out....
Looking for a 67-72 swb or blazer project in or around VA. Last edited by VA72C10; 07-14-2009 at 01:47 AM. |
07-14-2009, 09:32 AM | #6 |
Junior Member
if it were me... I would run a 12bolt with the trailing arm kit.... more effecient rear end and you can use the factory panhard bar mounts which packages the panhard bar pretty good.
07-14-2009, 01:08 PM | #7 |
The green truck from air ride is the stance I want when the bags are not aired up. I have seen on here where people perfer the triangular over the parallel. Porterbuilt when you refer to a longer panhard bar with the four link where is the best place to mount it. I've seen pictures of the Fesler red truck and it looks like he used the triangular four link. Porterbuilt do you have any pictures of the 66 rear suspension you installed. Also if I wanted to run the trailing arm kit could'nt I just make me a bracket for the 9 inch so that the panhard bar would fit. Thanks for all the feedback. I'm just trying to figure out which would be the best setup. Dbrasco
07-14-2009, 06:51 PM | #8 | |
If you like the 'engineered' look that the Strong Arm kit provides, it would be the easier to install @ home for those w/less than stellar fab skills but will cost more vs. the universal fit 4-bar (not including the labor to install since that can vary so much). Do you plan on removing the front inner fenderwells or cutting the bed floor?
07-15-2009, 02:16 AM | #9 | |
Here's a link to the 66 I was referring to: http://67-72chevytrucks.com/vboard/s...d.php?t=211503
www.PorterbuiltFabrication.com Phone: 480-297-2621 E-mail: sales@pbfab.com Find us on FaceBook under Porterbuilt Fabrication Specializing in Chassis and Suspension Components for your Classic Chevrolet Truck. We offer components from the following manufacturers: Porterbuilt Accuair Ridetech (Air Ride Technologies) Air Lift Wilwood Intro Unisteer ECE Gotta Show Air Lift Borgeson CPP Supporting this forum since 2003! Last edited by PBFAB.COM; 07-15-2009 at 02:17 AM. |
07-15-2009, 04:36 AM | #10 |
Thanks for all the info. The Rear Strong Arm kit looks like the kit I will be using. I will install different saddles for the 9 inch and then a supper trac bar from ECE that Scoti suggested. Poterbuilt thanks for all the help and that 66 looks awsome. Scoti I will be removing the inner fenderwells in the front. I'll have to fabricate something else up front. I had not planed on moving the bed floor if I do not have too. Dbrasco
07-15-2009, 09:59 AM | #11 | |
The ART trailing arm kit is very nice but costly as well. The 4-bar kits are cheaper but if the current set-up works & your not planning on laying frame, I would opt for using the stock truck arms w/a rear 'Cool Ride' kit (or piece together what I need) & add the longer Super Trac bar style of PHB. If the budget allows, the rear Strong Arm kit does look great.
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 07-15-2009 at 10:01 AM. |
07-15-2009, 10:14 AM | #12 | |
VA72C10
That could take your suspension budget from 4000-5000+/- with the ART front and rear components down to around 1000-1200 if you find some deals on the components like I have. Or get an accuair setup for a really slick ride height control system and have around 2000-2500 total in your setup. The blue truck below is just bags with c-notch. stock inners in front, stock bedfloor in rear with 20's.
Looking for a 67-72 swb or blazer project in or around VA. Last edited by VA72C10; 07-15-2009 at 10:21 AM. |
07-15-2009, 10:18 AM | #13 |
Even matching the rears ride height, it would be a benefit to remove or raise the fronts as they will want to buzz the tires frequently (depending on overall tire height).
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 07-15-2009 at 10:19 AM. |
07-15-2009, 10:55 AM | #14 |
VA72C10 is that your blue truck? That is the exact look that i'm wanting. So in the back you just installed bags to replace the springs and a different trac bar. In the front I was wanting upper/lower control arms, bags, spindles. Is that whats on the blue truck? I'm wanting to run 20 inch wheels all around. What size wheels are the front/back and do you know the back spacing? Also did that truck get a mini-tub for the bed inner fenders. I suppose the truck is aired out in the pictures. Do you have any pictures at ride height. Thx Dbrasco
07-15-2009, 12:23 PM | #15 | |
VA72C10
Wheels are 20 x 8, 5 1/4 bs front, 20 X 10 5 1/4 bs rear tires are 255/40/20 front,29540/20 back....taller than most go trying to get low, but I really like the look with a little more meat and they'll ride nicer too! I haven't seen any pictures posted at ride height but according to him, it sits right on the inners when aired out. No mods though to front or rear inners/tubs.
Looking for a 67-72 swb or blazer project in or around VA. |
07-15-2009, 04:18 PM | #16 |
67-72 parts collector,…
Everything posted above by Porterbuilt, SCOTI, and VA72C10 is super helpful info!
All stuff people need to think about, when bagging these old trucks. The only thing I would like to add is to measure your wheels for yourself. There are two different rearend widths from the factory. The 67-70 rearends are a different width than the 71-72 rearends, with the 71-72 rearend being about 1-1/2" wider. I know you are thinking about using a 9-inch, so this may not apply,... but don't get caught up using wheels sizes posted by someone else. If you do,... verify them for yourself.
Keith Convert to disc brakes. http://67-72chevytrucks.com/vboard/s...d.php?t=444823 Last edited by lolife99; 07-15-2009 at 04:20 PM. |
07-15-2009, 05:58 PM | #17 |
Another members ride w/the bed floor un-cut (floor isn't cut but the bedsides are modified for wheel width clearance) & front wheel wells un-modified. Dropped spindles & Firestone bags in front; 2" blocks on top of factory truck arms, bags, shock mounts relocated, & homemade C-sections & Super Trac bar....
255-40-20's on 20x8.5's; 295-40-20's on 20x9.5's (they might be 10's because of the soft lip).
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 07-15-2009 at 06:00 PM. |
07-15-2009, 06:24 PM | #18 |
Great info about the wheels. I figured using the 9 inch I would have to make my own measurements for the wheels. Both trucks are exactly what i'm looking for. I do have one more question about using the 9 inch with the trailing arm kit. Would the housing on the 9 inch (front) be a problem with the bars top/bottom between the shock mounts be a clearance problem for the 9 inch? The front housing on the 9 inch is bigger than the 12 bolt. Dbrasco
07-15-2009, 07:33 PM | #19 | |
I don't think it would be an issue from the 9" set-up I've seen on board-member 'FilmGuys' truck.
