Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Electrical
Old 07-11-2009, 05:16 PM   #1
milo
milo's Avatar
alternator help
hi everyone... so i finished instaling my painless wiring kit on my 53 chevy and i thought all was well but then i noticed that the voltage while the engine was running never got above like 12.4 so i went out got a new batt and a delco 10-si alternator. i should tell you that i put in 350 for an engine. anyway i put it all in ran the wire for the term 1 made a jumper for term 2 and started it up.... 13.5 i thought i was all set then i went to tern it off nothing so i unplugged the reg and it turned off.. put in a diode problem solved but now 12ish volts??? have tried it all put in a light tried one wire tried a fake voltage into the field excite i got nothing and am in need of help
milo is offline   Reply With Quote
Old 07-12-2009, 12:00 AM   #2
VetteVet
Msgt USAF Ret
VetteVet's Avatar
Re: alternator help
Refer to this website for some help.
http://www.6066gmcguy.org/charging.htm
I assume you had a generator on the truck. Did you have a charging light? Find the wire from the charging light that goes to the generator regulator and wire it to the sensing terminal on the 10SI alternator and then hook the jumper back up that went from the alternator Batt terminal to terminal 2 on the alternator. It may have an "F" instead of a 2 for field.
The website appears to be wrong to me in that the alternator terminals are backwards according to the description.
What did you get from Painless a stock 53 harness or something newer?
You can wire the red wire that goes to the external regulator to the Batt terminal and eliminate the regulator since the alternator has an internal one. You may or may not need the diode. Post back if you need more help.VV
VetteVet
metallic green 67 stepside
74 corvette convertible
1965 Harley sportster
1995 Harley wide glide
Growing old is hell, but it beats the alternative.
VetteVet is offline   Reply With Quote
Old 07-12-2009, 01:05 PM   #3
milo
milo's Avatar
Re: alternator help
i put in the universal kit. there was nothing to start so no light, no ammeter.... the painless kit has a wire labeled field excite which is the one i used for the sense wire... i had to wire in a diode.... then when it wasn't working i wired in a light...
so right now i have
ign power-----------light------diode------alternator terminal 1
Old 07-12-2009, 02:16 PM   #4
VetteVet
Msgt USAF Ret
VetteVet's Avatar
Re: alternator help
Well with the simplicity of the circuit you have, you may only be charging what the battery needs if that is the only load on the alternator. The charging light may not be enough resistance for the alternator regulator. You need around 80 ohms and about 5 watts. I would get the alternator tested and make sure it was working. On a setup like yours I don't think it would hurt a thing to start the engine and temporarily disconnect the negative post on the battery. If the engine stops then the alternator is not charging.I don't recommend this on the newer computer vehicles because of voltage surges but I have done it many times on the older cars and trucks and the only thing that went wrong was that I revved the engine with the lights on and they popped like flashbulbs, so don't do that.
we may need a diagram of your wiring circuit to determine where the problem is.
VetteVet
Old 07-12-2009, 02:58 PM   #5
fixit-p
fixit-p's Avatar
Re: alternator help
so right now i have
If the diode was installed backwards it would prevent power from getting to the alt and since it was working before the diode make sure the cathode (stripe on the diode) faces the alt.
1965 GMC shortwide big window
1969 Chevy C20 long (for now)
2005 Silverado 2500HD Crew Cab
Originally posted by:Abraham Lincoln "The trouble with quotes on the Internet is that it is nearly impossible to discern if they are genuine."
fixit-p is offline   Reply With Quote
Old 07-12-2009, 06:05 PM   #6
milo
milo's Avatar
Re: alternator help
yeah the diode is in right..... im thinking maybe something is up with the regulator, cause to be honest i cant find anything wrong with my wiring....
and when i first put it in, it worked..... i just want 13.5 volts haha
could putting in the light if it wasnt need cause a problem??
Old 07-14-2009, 12:21 AM   #7
milo
milo's Avatar
Re: alternator help
Ok so I started the truck this morning and stright to 13.5 worked for a little and then Went back to low volts I don't get it... Could it be that it needs a resistor in the exicte wire??
Old 07-14-2009, 09:19 AM   #8
stellar
Re: alternator help
sounds like something really simple like a loose belt or loose connection. The wiring sounds right. Ign -lite - diode-alt #1. Is there a pos wire to #2 terminal?
stellar is offline   Reply With Quote
Old 07-14-2009, 09:37 AM   #9
fixit-p
fixit-p's Avatar
Re: alternator help
Can you post a diagram of your system or verify it against this one.
Old 07-14-2009, 12:10 PM   #10
milo
milo's Avatar
Re: alternator help
battery-------switch---------light-------diode----------terminal 1
|-----------------------10ga--------------------------BATT
jumper from BATT-----terminal 2
ruff diagram best i could do real quick. im thinking of putting in a resistor instead of the light.. also is it a certain type of light you have to use i just wired in one i had lying around.
Old 07-14-2009, 12:16 PM   #11
milo
milo's Avatar
Re: alternator help
belts tight and i have checked every wire more then once. there is a jumper from the BATT post to the number 2.... im starting to think that the light i have in the circuit may not have enough resistance.... i dont know i have never had this problem before with any project
Old 07-14-2009, 05:33 PM   #12
stellar
Re: alternator help
Once the alt is excited it will continue to charge even if there is no connection to #1. The alt can be excited by momentarily touching #1 to pos post and it will start to charge for as long as the motor is running.
Where are you getting the low volt reading? have you tried the meter on another car to see if it is accurate? Even 13.5 is low unless the bat is already pretty low. The wiring looks right. I am now led to believe you have a high resistance connection in the alt pos circuit or a bad alt. If the pos post on the alt is even a little loose inside or outside the alt it will do what you say it is doing.
You may try taking a reading volts with the meter connected from bat neg post to alt pos post, and another reading with meter connected from bat pos post and alt case to look for a problem. let me know what you get. Mark
Old 07-15-2009, 06:59 PM   #13
mike66
mike66's Avatar
Re: alternator help
did you say that it was a four wire alt.......if it is a four wire,i think the " L" terminal is tied to the exciter wire from your ign. switch....i think that is all you need other than the wire from your starter.
mike
mike66 is offline   Reply With Quote
Old 07-16-2009, 03:35 PM   #14
neonlarry
neonlarry's Avatar
Re: alternator help
AFAIK a resistor is only needed in the excite circuit of the CS series alternators not the 10si and usually ditto the diode. You also mention unplugging the regulator and it turned off, do you still have the external regulator connected?
70 C/10 Light Red 350/TH350, HEI, Duals w/40 series Flows, 91 seat, LED taillights
99 Pontiac S/C GTP, SLP Ram Air hood, GMPP Konis & springs
95 Neon ACR, MP PCM, AFX UDP, 3.0 CAI
neonlarry is offline   Reply With Quote
alternator
