03-29-2003, 10:19 PM | #1 |
Ain't we cute?
How to remove rounded water pump bolt?
Yes, this is related to my other thread. This sh!t never ends. Why can't it ever be simple for me? :p
69 C10 2WD LWB Fleet 350/350 power front disc conversion (6 lug disc kit from gmcpauls) and new engine, PS, A/C, fresh fluids, SHE DRIVES! FOR SALE $3900 |
03-29-2003, 10:41 PM | #2 |
Is there any thing left of the head to get a bite on??? I use a 6 point socket only, and in your case I would recommend an impact socket to minimize distortion of the socket. I've gotten a few well rounded heads loose with that combination. If that fails, you can try a good visegrip, if there is room. Last, but not least, try rotating it a little to break it loose with a cold chisel held at an angle in the direction of rotation to remove said SOB bolt. These things are kind of like women... if they don't come easy, bang them a little harder!!!
69 GMC K10 ..some restoration required....still.. |
03-29-2003, 10:42 PM | #3 |
Don't know if you can get to it in the correct angle or not, but last time I had one rounded I center punched it and drilled the head off of it. Then I removed the part it was holding, heated the "stud" that was left and used a good set of vice grips to remove it. Took a little time but it worked.
68 1 ton dually 292, 2001 Sebring, 2004 Trailblazer, 11 Camaro Convertible. |
03-29-2003, 11:25 PM | #4 |
bolt
Grind or plasma cut the head off and then remove with vice grips after the pump leaves.....
1967 K30 Napco 292/SM420 original paint 30k miles 1968 K60 Napco 396/5spd. dbl frame 52" michelins 1969 K10 SWB GMC 454/4spd 6" 35's posi,hooks 1972 C30 longhorn,BB/AT,A/C,Tilt,Toolbox,lokr 1987 K20 Chevrolet Suburban. 6" lift. 5.7L/TH400 1979 K60 GMC Coleman 4x4, 427/Allison. |
03-29-2003, 11:27 PM | #5 |
Roadtrip!
bad bolt
O.K. Worst case. if you have access to a wirefeed welder, hold a nut on the end of bolt(not with fingers!) and weld it on there through center of nut. Try socket or wrench after that. Another possibility , cut head off bolt remove pump and try vise grips on remaining stud. Hope this helps.
03-29-2003, 11:51 PM | #6 |
Ain't we cute?
Good advice (and laughs)! Thanks, fellas!
03-30-2003, 05:24 AM | #7 |
I just bought a set of "Bolt-Out" Damaged bolt/nut remover set made by Craftsman. Looks like a socket but has hard tempered reversed spiral flutes inside to dig into that rounded bolt head.
1970 GMC 1500 Custom Original 350/TH350 Victoria, BC, Canada You can wish in one hand and crap in the other. See which one gets filled first. |
03-30-2003, 11:01 AM | #8 |
This is a 3/8 bolt with a 9/16 hex head? You can also try a six point 14 mm socket, it may fit tight so tap it on all the way with a hammer first. Working on older trucks makes six point sockets a necessity.
1971 C10 swb stepside 350/700R4/3.73posi (retired as of 4/22/03) 1998 S10 short bed 2002 S10 Blazer 1942 Oldsmobile 1958 Massey Harris Pony 1951 Wife Killingworth, Connecticut May those who love us, love us, any of those who do not love us, may God turn their hearts. And if God is unable to turn their hearts, may he turn their ankles so we may know them by their limping. A man who works with his hands is a laborer; a man who works with his hands and his brain is a craftsman; but a man who works with his hands and his brain and his heart is an artist. |
03-30-2003, 11:21 AM | #9 |
I am a Referee of life.
If you cut the head off try alittle wax of penetrating oil on the stud while it's still hot.This will help wick some of the lube into the threads and make it easier to get out.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" |
03-30-2003, 12:02 PM | #10 |
......one of the best tools i ever bought is a set of channel-lock nut busters..used to be called parrot nose pliers back in the day..not sure if you could get them into a water pump bolt but when these things bite they dont let go..they work 100 times better than vise-grips..
Ken Lyons, Slippery rock pa 68 short step 327 t10 4 gear 72 2wd blazer project 70 lwb 305/700r driver 78 caprice project 02 cavalier D.D ( hate it!!) |
03-30-2003, 01:29 PM | #11 |
its all about the +6 inches
How ever you end up getting it off, make sure you put some anti-seize compound on there when re-installing the pump.
03-30-2003, 03:26 PM | #12 |
CCRider
Is it only one bolt? If it is, take the other three out and rotate the water pump. It will proably loosen it enough to get it out with pliers
72 GMC Sierra SWB almost finished---- 84 Softail Olive Branch MS |
03-30-2003, 03:39 PM | #13 |
Did ya get it off. . . ?
03-30-2003, 05:44 PM | #14 |
probably what he's doing, seeing his avatar.... oh, you meant the bolt???!!
03-30-2003, 08:12 PM | #15 |
Try "turning it" with a hammer and chisel. Works sometimes.
03-30-2003, 09:35 PM | #16 |
Grubbin'
Try swearing a lot and then beating the sh!t out of the head with a hammer. Then call it a mother lovin sum of a beetch. Then hit it some more then spray some kroil in there and swear some more. Then get out the sledge and wack it. Then laugh out loud to no one in particular. Then get an angle grinder and cut the head off.
project rust attack 1969 Chevrolet LWB w/ 307. I got power steering now woohooooo!!!!!!! |
03-30-2003, 10:21 PM | #17 |
Ain't we cute?
LOL! Thanks, guys. The 6 point sockets did the job, had a 14mm ready too. I put some teflon tape on the bolts and some extra RTV around the block area and VOILA! no more leaky (Fingers crossed). Thanks, guys. I thought I was never going to get her going, and with some roofing jobs coming up, I needed her.
Thanks again for the help!! Jason
03-31-2003, 10:48 PM | #18 |
jmil1974 You got work, right on, and are you keeping your truck, I hope so.
03-31-2003, 11:56 PM | #19 |
I know this is basically a dead post since you got the bolt out but I am going to add this anyway. I have a friend who used to be a professional mechanic (he gave it up and bought a restaurant - go figure). He says the best way to get things like this out is to weld a nut or bolt onto it if you can get at it to do so. he says the heat from the welding will usually break it loose so that you can easily turn it out.
1968 Chevy - 292 with a powerglide |
03-31-2003, 11:57 PM | #20 |
Glad to hear you got it repaired!!
04-01-2003, 12:02 AM | #21 |
Designated A-hole!
First weld a washer to the stud and then weld a nut to the washer. Easier than just welding the nut to the stud!
"If it ain't broke, fix it 'til it is!" Being stupid ain't illegal. We're Still Debt Free Except for the House!!! www.daveramsey.com 70 GMC SWB Stepside project "Green Booger" soon to be 6.0l/4l80e 93 S-10 "Poppaw's Truck" |
