07-16-2009, 12:30 PM | #1 |
brake fluid runs from rear of master cylinder to front then out of it
I have a 72 chevy 4x4 3/4 ton. The brake fluid runs from the rear of master cylinder to front and then runs out of it under the cap. I put a new cap gasket in. The rear compartment of the master cylinder will run dry.
What could be the problem? Brakes work good if i keep fluid in both compartments. |
07-16-2009, 12:44 PM | #2 |
Re: brake fluid runs from rear of master cylinder to front then out of it
If I am understanding your problem correctly, it sounds like maybe a piston seal is leaking and you are losing fluid to the outside. You need a new master cylinder. Check under the master cylinder near the firewall (manual brakes) or power booster to see if it is wet under there. The fluid would have to leak out of the bore at the back of the master cylinder where it meets the firewall or the power booster. If not wet, then you must have a leaking rear wheel cylinder that is draining the rear compartment of the master cylinder. If they are not leaking, then must be a leaking rear brake hose or other leak in the rear brake system.
07-16-2009, 12:51 PM | #3 |
master cylinder i bought from autozne fore $13.. have had it for almost 2 years and have no problem with it yet... knock on wood
1972 C-10...402/400..flowmaster 40 series 1967 Mustang 347 stroker/C-4 1966 Mustang 289/3-speed 2013 Mustang V6/6speed w/300 ponies I may be 23, but i sure do knows 67-72s are sexy! Its not MPG its smiles per gallon! build started 11/25/08 build thread: http://67-72chevytrucks.com/vboard/s....php?p=2993796 |
07-16-2009, 01:05 PM | #4 |
Moderator
I have the same problem with my 3/4 ton and I have an NOS master cylinder on it. I have never had the problem with my 1/2 ton. Every time I read about this problem on here, it is always a 3/4 ton that has this problem. It sounds to me like the cap seal is not seating properly. I have heard guys recommend lightly sanding the mating surface on the top of the master cylinder to get a better seal from the cap....but I have not tried it yet.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man |
07-16-2009, 01:11 PM | #5 |
It has new rear cylinders. and its leeaking in the front part where the cap seats aginst the master cylinder. Somebody told me it might be a proportional valve needed adjusting cause it seems like theres to much pressure in the back compartment of the master cylnder. Then it pushes it to the front and builds up to much pressure and sprays out. Can you adjust the proportional valve
07-17-2009, 11:06 AM | #6 |
Been there, done that. Bad master cylinder from AutoZone.
85' CUCV M1009!!! The newest addition! 6.2diesel, Th400, NP208, & only 36k miles! 70' C-10 LWB Fleetside - Looking good these days! 05' Dodge Neon 88' Winner Escape Sport 1750 - 4.3v6 94' Seadoo SP 84' Honda TRX200, bare nekkid. Just a frame & tires. Always looking for another project or any good deal! |
