#26 |
Re: Poll: Cut the frame or no??
You might run into a problem selling pickup after frame cut, alot of the public does not understand.
#27 |
C/10 CLUB MEMBER
![]() Join Date: Jul 2003
-Ron- ![]() Last edited by OldSkool71; 07-21-2009 at 08:07 PM. |
#28 |
![]() Join Date: Dec 2008
i would look for another longbed frame to cut, your truck looks nice enough that I would not want it out of service while the frame is being modified?
1969 Short Stepside 1969 4 WD Suburban 1970 1 Ton Dually....Misfit oh, and a 2001 HD 2500, 8.1 Allison Shortbed 4 Door |
#29 |
![]() Join Date: Jun 2002
Cut it & don't look back. I step cut mine, & added diamond shaped gussets on the inside. Very quick & easy mod. Cutting the bed floor is much more time consuming just because of the amount of cutting / welding.
The kid Build threads: 51 Jimmy http://67-72chevytrucks.com/vboard/s...d.php?t=154951 http://67-72chevytrucks.com/vboard/s...d.php?t=219902 http://www.classictrucks.com/feature...uck/index.html 68 C10 http://67-72chevytrucks.com/vboard/s...ad.php?t=50348 |
#30 |
i'd reuse the original long bed and rear frame and build a matching trailer. that way you have the extra length when you need it. was thinking about doing that with my 87 ram 50 (mitsubishi). it is a short bed truck and there are times the longer bed can be handly (snowmobile, motorcycle, etc, etc.) for a vintage chevy, i'd be inclined to keep it stock. the short beds are very sporty (and thus extremely popular) but there are many advantages to the longer wheelbase and larger cargo volume. best of luck with your project!
