Old 07-23-2009, 09:26 PM   #126
menace121978
menace121978's Avatar
Re: Glock's new project: "Fred"
right on congrats buddy!! no stopping you now!
btw... what alls on that parts list of yours? you already have me beat as far as research and making lists AND finding the best deals!
i think you have at least 2 trucks on me already!!.
"Dennis the Menace"
1978 Silverado (2wd, 1/2 ton, short bed)complete nut & bolt frame off restomod LQ9/4L80E
MY LS SWAP/FRAME OFF BUILD BOOK
2006 TBSS way too much to list
menace121978 is offline   Reply With Quote
Old 07-23-2009, 10:06 PM   #127
glock35ipsc
Next project: 1970 K10
glock35ipsc's Avatar
I've got a good list of parts going at work, now I need to get on the ball and start finding price deals. I'm going to make my own mounts, so that saves a little. I budgeted having Jesse at Wait4me do the harness, but I may do that too. That would save about $300. I'll probably do my own exhaust again. I was going to get a used tranny from C.A.R., but I talked to a buddy of mine today and he's going to build me a tranny for the same price, with a 3 year/70,000 mile warranty. Plus I'm noting little things too as the pop in my head, like hose, hose clamps, fluids, etc.
I'll get my list updated and post it here in the next few days.
Bob
1970 Chevy K10 LWB "Goldie" 350/TH350 next project!!
1981 Chevy C10 LWB 355/TH350 - My son's truck
LS SWAP FORUM! Tons of LS swap info here!
PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET!
CLICK HERE FOR THE FAQ INDEX by KRUE
glock35ipsc is offline   Reply With Quote
Old 07-23-2009, 10:54 PM   #128
menace121978
right on... pm sent
"Dennis the Menace"
Old 07-24-2009, 08:23 AM   #129
JohnC
JohnC's Avatar
I don't think it's right that you guys are just rubbing it in like that!
Bob I think you should build another dash like that for Fred. It should be easier this time around because you have done it before!
The new bezel looks awesome. When I get to the interior I may have to give Cheyenne a call, and run over there and pick one up.
JohnC is offline   Reply With Quote
Old 07-24-2009, 09:19 AM   #130
glock35ipsc
Hehehhee
Custom dash for Fred?? !!!! Maybe waaaaaaay down the road, but I promised myself I wouldn't get carried away with this one.
The dash thingy is a pretty good deal for the price. As long as the plastic is in good shape, this makes it look new again.
Bob
Old 07-24-2009, 09:54 AM   #131
glock35ipsc
OK Dennis, I know there is more than this, but this is what I have so far:
Engine
Transmission
Engine mounts
Oil pan
Harness and PCM tune
Exhaust system
A/C (1)
Cooling system (2)
Frame modifications (3)
Transmission x-member mods
Fuel system (4)
Driveshaft modifications
Plugs
Plug wires
Vacuum line
Hoses
Clamps
Thermostat
Antifreeze
P/S fluid
Brake fluid
Transmission fluid
Rear differential fluid
MAF sensor, used
New O2 sensors
(1) Vacuum, leak test and charge. Manifold, hoses
(2) Radiator (?), electric fans, shroud
(3) Notching and boxing for A/C and/or Oil pan is necessary
(4) Pump, filter/reg, lines, fittings
Bob
Old 07-24-2009, 01:48 PM   #132
menace121978
thanks Bob!
i was just thinking if we run duel tanks w/ the return line from the vette filter does the return go back through the switching valve and then back to which ever tank were on?
"Dennis the Menace"
Old 07-24-2009, 01:57 PM   #133
glock35ipsc
Yes, I believe that from the valve it then returns to the particular tank that is selected.
Bob
Old 07-24-2009, 03:23 PM   #134
glock35ipsc
My motorcycle just left the parking lot, so I'm off to the bank to deposit the
Then, it's: "Hello, Certified Auto Recycling? Yes, about that 5.3 Vortec we have been discussing........"
Bob
Old 07-24-2009, 03:43 PM   #135
JohnC
JohnC's Avatar
SWEET!
Old 07-24-2009, 04:40 PM   #136
menace121978
Bob, on your list you mention spark plugs... go w/ the stock ac delco plugs. last summer we tested the ngk's and a number of others and the ac's pulled more h.p. on back to back dyno pulls in the goat's ls2. also the exhaust... (flows sound awesome and its what im going to run in the truck) but on the ls2 actually lost h.p. compared to magnaflo, slp, ect. and yes i know theres lots of variables but everything that could be controlled was. there is a few locked threads over on ls2gto.com about this but i just thought i'd mention it now rather than later. knowledge is power! Dennis
"Dennis the Menace"
Old 07-24-2009, 05:01 PM   #137
glock35ipsc
I hear ya! ACDelco has always had my back! I only put them on my list because I want all the critical stuff like that to be new, so I'm not chasing around weird demons if there are issues.
I'm with you on the exhaust too. Flows are what I'll be using too, I just flat-out like the sound. In my case, and for Fred's use for the next couple of years, a few lost ponies won't matter.
Originally Posted by menace121978
knowledge is power!
Bob
Old 07-25-2009, 09:51 AM   #138
nlped
nlped's Avatar
Again Glock, you are the man. I can't wait to see your 5.3l install thread.
Inspirational
Carter
1968 Chevy SWB Fleet... Walt
1963-1/2 Ford Falcon Futura...Martha
nlped is offline   Reply With Quote
Old 07-26-2009, 11:36 AM   #139
Jonboy
Slots go on anything!
I have always liked Flows also, but I used Zoomer's exhaust on my CTS-V. It is hands down the best sounding exhaust I have ever had on a car. The Cadillacs use 2.5" duals with a big resonator right behind the trans, and two large mufflers right at the end. The Zoomers exhaust uses a baffled chamber on each pipe in place of the resonator and also in place of the mufflers. Had to be less restrictive than stock. Maybe you could use something similar to that. It has a little pop on deceleration (mostly because of the heavy stock flywheel, I think), but I really don't pick up any drone on the highway. Either way, I am sure it will sound good.
Jonboy is offline   Reply With Quote
Old 07-27-2009, 10:35 AM   #140
glock35ipsc
I got all the fuel system parts ordered this morning.
Now I'm getting ready to call a yard in Cali that Dennis turned me on to. Trying to get a deal on an engine and trans combo now instead of just the engine.
Bob
Old 07-27-2009, 10:38 AM   #141
menace121978
good luck! just hope the shipping is reasonable...
"Dennis the Menace"
Old 07-27-2009, 10:45 AM   #142
glock35ipsc
I just got off the phone with a guy named Roger, Scott didn't answer. Shipping is good @ $200, but he quoted me $2500 for a complete low mile combo. I told him that was out of my budget and that I need to look at some things and I would call him back. I really don't need all the things that they offer to send, so I think I can get him down lower.
Bob
Old 07-27-2009, 10:46 AM   #143
JohnC
JohnC's Avatar
Sweet keep us updated.
Old 07-27-2009, 11:07 AM   #144
nlped
nlped's Avatar
Here are some Egay listings that may or may not help. Worth a look though...right?
http://cgi.ebay.com/ebaymotors/05-06...Q5fAccessories
This place has a lot of really inexpensive listings, and may be able to accomodate your needs. Might be worth a call.
Carter
Old 07-27-2009, 11:08 AM   #145
menace121978
damn, i think thats bull... i have a quote in front of me that says $2000 w/ $175 for tax.(that you wont have) i'd defiantly keep trying scott. funny though, scotts' last name is rodgers.
i have the vin # of the tahoe it was coming out of too. worst comes to worst (if they keep stiffing you) i'll fax this quote to ya! 5 hun is 5 hun.
try asking for that kid octavian. he's is the one that turned around and asked how much and scott said $2000 from radiator to fuel tank...
btw $200 for shipping seems like a hell of a deal. i expected a lot more...
how much(if you dont mind) did the fuel system end up being?
"Dennis the Menace"
Old 07-27-2009, 11:11 AM   #146
glock35ipsc
Oh heck yeah, I'd take a fax of that! That would definitely help me negotiate that down. I'll PM my fax number to you!
Edit - Forgot to add, fuel system total so far is $292.23. That's the filter/regulator with fittings, 2 fuel pumps and the high psi switch valve. Still need hose and SS clamps.
I got free shipping through JCWhitney (saved ($15.95) and 5% off at Rock Auto.
Bob
Old 07-27-2009, 04:33 PM   #147
nlped
nlped's Avatar
Sent you a pm that may make you smile.
Carter
Old 07-27-2009, 04:36 PM   #148
glock35ipsc
Engine and trans are on the way!! Well, once they get them yanked out of the truck they will be. 58k miles, and everything INCLUDING the kitchen sink will be sent.
Bob
Old 07-27-2009, 04:41 PM   #149
nlped
nlped's Avatar
Never mind
Carter
Old 07-27-2009, 04:44 PM   #150
glock35ipsc
Thanks for the link! I had looked at those guys before, but their engines are sold without accessories. By the time the minimum necessities were added, it was much higher than any fully dressed ones I had found.
I'm pretty happy with what I found. They will unbolt the engine and trans mounts, and unplug and include every harness on the truck related to the powertrain and pull it as one unit. Radiator and shroud, fuel system components, trans yoke, head pipes, fuse block...... everything. I will probably be able to sell a lot of it and recoup a little bit of money.
Bob
