07-21-2009, 04:45 PM | #226 |
Next project: 1970 K10
Re: Finally "Silvers" build thread!! ('78 swb 2wd silverado)
Well then, throw those away and print this! I made a couple changes, like adding two different connection options for the filter/regulator.
* AC Delco EP381 in-tank pumps. $69 each at http://store.getgmparts.com/fe0114.html * Pollak high psi tank selector valve, this is a direct OEM replacement (JC Whitney p/n ZX812705U) $83 * Fuel selector switch from an 87, replaces existing dash switch (AC Delco p/n D7089C) $11.50 at rockauto.com * Corvette filter/regulator if running a returnless/1 line system (WIX p/n 33737) $34 at rockauto.com If you don't already have in-tank pumps, you'll need sending units: * Dorman p/n 692027 for the driver side, $94 at rockauto.com * Dorman p/n 692044 for the passenger side, $101 at rockauto.com To make the connections at the filter/regulator: The inexpensive way: * 3/8" female connector (Dorman p/n 800121) $6.30 at rockauto.com * 5/16" female connector (Dorman p/n 800120) $6.30 at rockauto.com * 3/8" x 12" double ended male connector (Dorman p/n 800155) $8.20 at rockauto.com The "nicer looking" way: * 3/8" to -6AN straight fitting, Russell #640850 (this one is also is needed for connection to the fuel rail) * 5/16" to -6 AN straight fitting, Russell #640860 * -6AN to -6AN union, Russell #660350 * -6AN tube sleeve, Russell #660650 * -6AN tube nut, Russell #660571 And be sure to use a good quality high psi fuel pressure hose for connections, not regular fuel line. And use smooth stainless fuel hose clamps that look like these:
Bob 1970 Chevy K10 LWB "Goldie" 350/TH350 next project!! 1981 Chevy C10 LWB 355/TH350 - My son's truck LS SWAP FORUM! Tons of LS swap info here! PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET! CLICK HERE FOR THE FAQ INDEX by KRUE Last edited by glock35ipsc; 07-29-2009 at 04:08 PM. |
07-21-2009, 05:32 PM | #227 |
Bob, you are the man! very much apprieciated buddy! feel free to post any other info such as radiator,headers, mounts, ect.
not sure which headers i'm going to go w/ yet. but 98-00 f body stock manifolds or shorties will work. i still need to call the smog ref. to find out what headers they expect me to run to pass. thats going to be the deciding factor for me... to pass or not to pass
"Dennis the Menace" 1978 Silverado (2wd, 1/2 ton, short bed)complete nut & bolt frame off restomod LQ9/4L80E MY LS SWAP/FRAME OFF BUILD BOOK 2006 TBSS way too much to list Last edited by menace121978; 07-23-2009 at 03:32 PM. |
07-21-2009, 06:19 PM | #228 |
Great info Bob!
07-23-2009, 08:40 AM | #229 |
This is the most impressive thread I have seen yet! Great job! I usually browsing the 60-66 because that's what I have, I came over here because I did a swap of one of your guys front ends into my truck and was wondering how to push in the new upper and lower bushings and ran across this thread, I'm most impress with your work.
07-23-2009, 02:52 PM | #230 |
oklahoma, thanks for the nice words man!
i have an update john! i got the steering gear box today! all painted and bolted up w/ new hardware. i also aligned the tierod ends so the tires arent so / \ bowed. looks good but i kinda wished i would have smoothed out the casting after i got it on and started looking at it. i know i got serious problems huh? i'll post pics tonight!! just need to order the prop. valve and go pick up my drop shocks!! then its on to fuel system ordering (thanks Bob) and continue shopping for a "ls power!!" plant...
"Dennis the Menace" 1978 Silverado (2wd, 1/2 ton, short bed)complete nut & bolt frame off restomod LQ9/4L80E MY LS SWAP/FRAME OFF BUILD BOOK 2006 TBSS way too much to list |
07-23-2009, 03:28 PM | #231 |
Good luck on your engine search! I'm gonna plug Certified Auto Recyclers once again just in case you don't have any luck finding something local. I have been on the phone all morning with yards in the Denver metro area. So far the best deal I've found was $700 for a basic long block, and by the time he added all the bolt-on's to the price, it was almost $300 more than the one I'm getting from Alabama, which includes shipping! Craigslist and eBay haven't turned up anything for me either.
Hopefully they are more plentiful around your area! I did get a number for a place called RCS (1-800-259-4020) by member Jonboy, they are in the DFW area. Ya might try them too.
Bob 1970 Chevy K10 LWB "Goldie" 350/TH350 next project!! 1981 Chevy C10 LWB 355/TH350 - My son's truck LS SWAP FORUM! Tons of LS swap info here! PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET! CLICK HERE FOR THE FAQ INDEX by KRUE |
07-23-2009, 04:00 PM | #232 |
Rub it in why don't ya! Can't wait to see the pics. If it bothers you that much you might as well take it back off and do it now, instead of months down the road when you can't stand it anymore, and then there is more stuff in the way! I know how it is to be OCD on stuff.
07-23-2009, 04:06 PM | #233 |
LOL, that's the reason my 68 went the direction it did!!
07-23-2009, 04:07 PM | #234 |
That's why I'm trying my hardest to not tear mine apart that much right now.
07-23-2009, 04:11 PM | #235 |
My wife said she is going to hold me accountable for the statement I made of "the cab is NOT coming off the frame on this one!!!'
07-23-2009, 04:18 PM | #236 |
i'm glad im not alone... misery loves company!
07-23-2009, 04:24 PM | #237 |
07-23-2009, 08:35 PM | #238 |
My fiance was home when the UPS man came today and he had an armload of suspension parts for Bob. She immediately came inside and told me if the UPS man came again without a pair of shoes for her I was in deep POO. I ordered her a pair of flip flops off of Egay...
07-24-2009, 08:25 AM | #239 |
Good thing you went with a shoe that won't fly very well when she hurls it at your head!
07-24-2009, 09:08 AM | #240 |
CHEVY ONLY |
07-24-2009, 09:26 AM | #241 |
07-24-2009, 04:25 PM | #242 |
alright guys redid the steering box... heres what it looked like the 1st time around.
and this is how it looks now. and what the heck... LS POWAAA!!!! cant wait till that chassis looks like that! i'm wondering if all my stuff on the goat will work on the 5.3?
07-24-2009, 04:30 PM | #244 |
5.3 or 6.0... theres a 2002 6.0/4l80e for $2500 on craigslist... really wanted the dbw but i want to see how bad he wants to sell it.
07-24-2009, 04:32 PM | #245 |
Badass
talking about the gto lol
but what is a 4l80e a 5 speed?
Think outside the box? -84c10 (1stcar)→My Build← -00 Saturn 5spd drop a gear and disappear! 1/4:13:90 |
07-24-2009, 04:43 PM | #246 |
4L80E:
4 = # of forward gears L = longitudinal placement in chassis 80 = Number given to correspond with the vehicle's GVWR E = electronically controlled
07-24-2009, 04:45 PM | #247 |
sorry man your post was too fast after i posted the pics!
he's a 6.0 backed by the 6 speed. and yes its a he because you cant have balls that BIG and be called a she!! the 4l80e is just the heavy duty 4 speed auto.
07-24-2009, 04:46 PM | #248 |
wow! Bob's all over it! thats some good info.
07-24-2009, 04:54 PM | #249 |
Si
Bob 1970 Chevy K10 LWB "Goldie" 350/TH350 next project!! 1981 Chevy C10 LWB 355/TH350 - My son's truck LS SWAP FORUM! Tons of LS swap info here! PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET! CLICK HERE FOR THE FAQ INDEX by KRUE Last edited by glock35ipsc; 07-24-2009 at 04:56 PM. |
07-25-2009, 09:49 AM | #250 |
I like the steering sector black too. It didn't look bad silver, just better in black w/ the minimal silver trim. Just my .02.
And Glock, you are on the ball! |
