Old 07-25-2009, 06:24 PM   #1
gainesee
72 GMC ignition
Considering an HEI for my 350. Any suggestions?? Will putting the HEI in give me noticable throttle response? Thank you for any feedback!!
gainesee is offline   Reply With Quote
Old 07-25-2009, 07:45 PM   #2
68gmsee
Active Member
68gmsee's Avatar
Re: 72 GMC ignition
Lots of positive responses when I asked about HEI on my 68 six cylinder. I actually did notice better throttle response. It probably would be more noticeable in a V8.
68gmsee is offline   Reply With Quote
Old 07-25-2009, 08:04 PM   #3
turp mcspray
turp mcspray's Avatar
Re: 72 GMC ignition
If you get a used one, make sure you change the advance curve. You'd be amazed at how much power you can gain by changing the SLOW/LAZY advance setup that most factor HEIs come with!
Turp Mcspray
New life for an old 2wd, farm blazer
http://67-72chevytrucks.com/vboard/s...d.php?t=505987
My Blazer build http://67-72chevytrucks.com/vboard/s...d.php?t=342299
turp mcspray is offline   Reply With Quote
