Old 07-25-2009, 10:02 AM   #1
samdjr74
56 3100 Brake upgrades, need advice
Hi All,
I want to finish up my brakes next month, so far I've upgraded the frpnt and rear suspension so I'm running GM disc's on all 4 wheels. Next is the master clynider/brake booster. Here's where I need some help. Should I go firewall mount or frame mount? What's the advantages and disadvantages to each? Besides the master cylinder what else do I need to buy? I see adds that say I need a pressure valve, combo valve, etc, do I need them? I don't have the stock pedal but the frame mount for the original master cylinder is still intact and good.
Any help would be great, thanks,
Sam
samdjr74 is offline   Reply With Quote
Old 07-25-2009, 04:59 PM   #2
mr48chev
mr48chev's Avatar
Re: 56 3100 Brake upgrades, need advice
On that particular truck the only advantage of a frame mounted master cylinder and booster would be a cleaner firewall and engine compartment. If you are into the clean firewall look and don't like stuff hanging out to block the view of the engine, go under the floor, If you really don't give a rip if people see your mc and booster hanging off the firewall, put it there where it is a lot easier to get to.
The truck came with a firewall mounted master cylinder and swing pedals so I would imagine it would be a lot easier to mount it on the firewall and a lot easier to check and service it.
Old 07-25-2009, 05:22 PM   #3
samdjr74
Thanks, but what about the proption values and residual pressure values, are they needed? Also my truck came with the mc mounted on the frame so mounting to the frame would be eaiser but to the forewall wouldn't be too hard as well
Old 07-25-2009, 05:55 PM   #4
OrrieG
OrrieG's Avatar
Mr. 48 summed it up. On my 59 I put it underneath, I wanted the clean firewall and use of the stock pedal. Bad news is in the future filling and replacement will be more of a hassle. Look at post 13 and 39 in my build thread to see the basic layout. I built my own brackets and used the 74 master cylinder and Prop valve with a hotrod 8" vacuum booster.
Old 07-25-2009, 07:06 PM   #5
low57
low57's Avatar
Keeping the master cylinder and booster underneath the cab in my opinon would be easier simply for the fact that if you go the firewall route then you have to cut into the firewall and also brace up under the dash where the pedal assembley will go. As far as using residual valves you need to use one for the front and one for the rear if the master cylinder is under the cab and I believe that if you have four wheel disc 2 pound residual valves are needed. Have you thought about going the hydroboost route under the cab? I am in the process of putting a hydroboost under the cab of my 57.
low57 is offline   Reply With Quote
Old 07-26-2009, 08:28 AM   #6
samdjr74
I didn't even think about a hydro boost, what are the benefits of a regular booster?
Old 07-26-2009, 08:57 AM   #7
ChuckDriver
A320 Pilot/USAF Retired
ChuckDriver's Avatar
I went with the underfloor mount from Master Power Brakes. My truck has a camaro clip up front and a chevelle rear with a big drum brake kit. I followed their plans and used the prop valve and both 10lb and 2lb residual valves. The brakes work great, just like that of a camaro! Here are some links to their site and setup diagrams.
http://www.mpbrakes.com/uploads/docu...rumdiagram.pdf
http://www.mpbrakes.com/uploads/docu...erfloorpdf.pdf
http://www.mpbrakes.com/products/pro...product_id=192
ChuckDriver is offline   Reply With Quote
Old 07-26-2009, 09:06 AM   #8
ChuckDriver
Here's a pic of my setup.
Old 07-26-2009, 10:37 AM   #9
blackdiesel
blackdiesel's Avatar
Well, I like the clean firewall also. But on my truck and grandpa's truck we have the M/C and booster on the firewall, and dad has the CPP uint under the floor, all have 4 wheel disc. Mine and grandpa's truck stop on a dine and give change, but dads, you better not tail gage or you will be buying a new grill. I dont know if it's a bad booster or if it's because his is a 8" and ours is like 11". Under the floor is alot easier.
'57 Chevy Pickup
'56 GMC LCF Cummins
'38 Chrysler Royal
'57 2wd change
http://67-72chevytrucks.com/vboard/s...light=speedway
blackdiesel is offline   Reply With Quote
Old 07-26-2009, 11:36 AM   #10
MrSinister
MrSinister's Avatar
I had the underfloor and then went with the firewall mount on my truck and I definitely like the firewall mount. the firewall mount puts the pedal in a much more comfortable position and I had alot of problems with exhaust routing and tranny mounts with the underfloor mount. both of them were from cpp and they both were easy to install and are well made.
'56 Big window
350/700r4
9" rear w/disc
MrSinister is offline   Reply With Quote
Old 07-26-2009, 03:05 PM   #11
blackdiesel
Mrsinister, Did one work better that the other, or just pedal position? Where the booster both the same size?
'57 Chevy Pickup
'56 GMC LCF Cummins
'38 Chrysler Royal
'57 2wd change
Old 07-27-2009, 01:32 AM   #12
MrSinister
MrSinister's Avatar
the underfloor booster had an 8" single diaphram booster and the firewall came with a 8" double and it did make a big difference. but it was mostly the better angle that i was looking for, it's going to be much more comfortable especially since i plan on driving the snot out of it when i'm done
'56 Big window
350/700r4
9" rear w/disc
