Old 07-15-2009, 09:01 PM   #151
gcburdic
Restoration Virgin!
gcburdic's Avatar
Re: Project: Mistress
Okay...finally installed the VC and air cleaner cover....what do ya think?...
I installed perma-dry plus gaskets and reused the T-bars hold downs (which I DON'T like)...I'll be changing those out....But noticed there was oil leaks on the passenger side about half way back along the outside...I don't want to reuse the spreader bars, but how can I get it to seat better??
Geoff with a G
1968 Chevy C10 SWB The Mistress
1972 Custom Deluxe C20 Suburban A Suburban Named Isabella
1966 Ford Mustang Mama's High School Graduation Present
gcburdic is offline   Reply With Quote
Old 07-15-2009, 09:23 PM   #152
VA72C10
VA72C10
VA72C10's Avatar
Looks good in there. Other than the spreader bars, I'm not sure...maybe someone else will chime in.
Old 07-15-2009, 10:14 PM   #153
Hart_Rod
Hart_Rod's Avatar
Maybe the studs are too long on the T bars and bottoming out prior to tigtening up on the valve cover. Try adding a couple of washers to the T bars. Did you let the motor get hot and then retighten them? This seems to help the gaskets seat. Also, I always run a thin layer of permatex on the valve cover before placing the gasket on, but that's just me. Hope this helps.
Hart_Rod is offline   Reply With Quote
Old 07-16-2009, 11:24 PM   #154
highperf4x4
Looks good!
highperf4x4 is offline   Reply With Quote
Old 07-26-2009, 08:49 PM   #155
gcburdic
Restoration Virgin!
gcburdic's Avatar
So I finally worked on the Mistress a little more this weekend....needed to install the radio and kick panel speakers...It was a pretty easy install once I found a good ground....next I finally got lighting to the gauges in the center panel and hooked up the voltmeter.....then I finally decided to get the fuel gauge working...I had wired it wrong (it took me 2 nights to figure it out, but I got it resolved).....and since I had the bench seat out, I went ahead and installed my original lap belts that were in the truck when I bought it (gonna install 3 pt belts soon so these are temporary)....also, finally got the engine bay cleaned up by installing stainless steel bolts as hold downs on the valve covers (removed the T-bars).....here's a looky at my progress....
Geoff with a G
Old 07-26-2009, 09:10 PM   #156
MrBlue
MrBlue's Avatar
gcburdic,
WOW! Love that Color!
The color really pops out at you!
So how does the exhaust sound on the road?
THanks
MrBlue
MrBlue is offline   Reply With Quote
Old 07-26-2009, 09:47 PM   #157
gcburdic
Restoration Virgin!
gcburdic's Avatar
Originally Posted by MrBlue View Post
gcburdic,
THanks
MrBlue
Hey Thanks so much MrBlue.....
exhausts sounds like....wah, chirp, wahhhhh, chirp, wahhhhhhhhhhhhhhhhhhhhhhh (only a TH400)
just kidding.....still sounds good to me, but will take it out back at some point.....just sounds too good to me right now!!!
When I first drove it home (took about an hour), it was cold out and I rode home with the windows up.....When I got out it was like I had the bass in the stereo up full blast for the last hour...
Thanks for looking!!!
Geoff with a G
Old 07-26-2009, 09:55 PM   #158
lclippard
lclippard's Avatar
sweet truck man. i may have to swing one exit over and check it out sometime. i keep seeing all these awesome colors and cant seem to decide what color i want mine. i guess i should stay away from this color since we'll be running in the same town(s)
69 burb/01 yukon chassis
65 Comet Caliente 289 4 Door Sedan
99 Millenia S (supercharged) 4 Door Sedan
02 Yamaha R6
69 swb c10 http://67-72chevytrucks.com/vboard/s...36#post3799136
building with a buddy:
85 C10 http://67-72chevytrucks.com/vboard/s...94#post3708194
lclippard is offline   Reply With Quote
Old 07-27-2009, 10:49 AM   #159
my67chevytruck
Under Construction
my67chevytruck's Avatar
looking good Geoff!
Heath
subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php
http://67-72chevytrucks.com/vboard/s...d.php?t=157669
FAQ how to's
1956 Chevy Apache
1967 C10 SWB FleetSide (under construction)
1969 K10 SWB FleetSide (Future Build)
1972 C10 SWB Stepside (Future Build)
56 chevy truck :
http://www.cardomain.com/ride/2955823/1
67 truck build:
http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1
69 k10:
http://67-72chevytrucks.com/vboard/s...d.php?t=389470
my67chevytruck is offline   Reply With Quote
Old 07-27-2009, 09:10 PM   #160
gcburdic
Restoration Virgin!
gcburdic's Avatar
Originally Posted by my67chevytruck View Post
looking good Geoff!
Thanks Heath!!!...I appreciate it!!!
Geoff with a G
Old 07-28-2009, 02:01 AM   #161
highperf4x4
lookin good brother!
Old 07-28-2009, 09:25 PM   #162
gcburdic
Restoration Virgin!
gcburdic's Avatar
Let me know when you want to swing by.....got any pics of your truck posted up here??.....How far along are you??....Maybe I can help you out some if you need it!!!....Do whatever color you want....make it yours....
Thanks brother!!!
Geoff with a G
Old 07-29-2009, 07:21 AM   #163
72BlckButy
Tot Roddin'
72BlckButy's Avatar
I think we are going to need a video to confirm this...
Still lovin' the project Geoff!
-Nate
1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6)
1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior)
2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package)
72BlckButy is offline   Reply With Quote
Old 07-29-2009, 03:06 PM   #164
my67chevytruck
Under Construction
Geoof, how did you go about painting the VC's, and breather. I have contemplated touching up my son's, but alot of masking.....
Heath
FAQ how to's
1956 Chevy Apache
56 chevy truck :
67 truck build:
69 k10:
Old 07-29-2009, 03:45 PM   #165
gcburdic
Restoration Virgin!
gcburdic's Avatar
Heath,
It was actually super easy.....I actually taped up the 1st cover and sprayed it with some high temp semi-gloss (I didn't waste my time taping the second one or the Air cleaner cover)....I waited about 5 minutes, then put some minerial spirits or paint thinner on a rag and wiped off the finned/ raised and over sprayed areas.....then wiped it down real good with a wet cloth.....be sure to use cloth that won't leave lint like I did originally!!.....hope this helps and let me know if you need anymore info!!
Geoff with a G
Old 07-30-2009, 08:59 AM   #166
my67chevytruck
Under Construction
cool, i was thinking along those lines, thanks for the info.
Heath
FAQ how to's
1956 Chevy Apache
56 chevy truck :
67 truck build:
69 k10:
Old 07-30-2009, 11:22 PM   #167
highperf4x4
I second the motion......
Old 08-02-2009, 09:19 PM   #168
gcburdic
Restoration Virgin!
gcburdic's Avatar
Stopped by this cool car wash in Cooleemee, NC on my way home from a car show this weekend in Winston-Salem.....I never really recognize the rake on the Mistress unless I take pics of her!!!
Geoff with a G
Old 08-03-2009, 07:06 AM   #169
my67chevytruck
Under Construction
lookin good....
Heath
FAQ how to's
1956 Chevy Apache
56 chevy truck :
67 truck build:
69 k10:
Old 08-03-2009, 11:43 PM   #170
89 GMC Sierra
I love the way your truck turned out it is fricken awesome.
Right now my Dad and I are in the process of fixing up my truck its a 89 GMC Sierra c1500 short box. We decided to paint it a tangerine color that looks similar to the color on your truck and after seeing how great it turned out on your truck it puts my mind at ease.
I love the way your truck turned out its just awesome haha
89 GMC Sierra is offline   Reply With Quote
Old 08-06-2009, 04:49 AM   #171
Tim_A
Tim_A's Avatar
sweet truck, man! Enjoyed your thread. Something tells me that mine can take longer than anticipated.
'67 Impala
'69 Chevy 350 C-10 shortstep
Tim_A is offline   Reply With Quote
Old 08-16-2009, 07:36 PM   #172
gcburdic
Restoration Virgin!
gcburdic's Avatar
lookin good....
Thanks Heath!
Thanks alot 89 GMC Sierra....post up some pics when yours gets painted!!!
Thanks Tim A.....yeah, I thought it was funny when you said it'll be a quick upgrade!!!
Here's the Mistress at the Lake!!!....Took this with my camera phone...turned out pretty good!
Geoff with a G
Old 08-16-2009, 10:06 PM   #173
VA72C10
VA72C10
VA72C10's Avatar
That's a sweet camera phone picture
Old 08-17-2009, 07:20 AM   #174
my67chevytruck
Under Construction
Ah.... aint nothing like being alone with your mistress at the lake!!
Heath
FAQ how to's
1956 Chevy Apache
56 chevy truck :
67 truck build:
69 k10:
Old 08-25-2009, 07:14 PM   #175
72mistressc10
72mistressc10's Avatar
Just an FYI I have a 72 c10 long bed, your truck has been officially selected for my inspiration. I might even go as far as jacking your color also. Mine will have minor differences and probably won't look as sweet as yours but none the less, I will try my darndest.
1972 C10 LWB Cheyenne Super
God Said,"Owning A 10 Second Import Is Like Coming Out Of The Closet, In The End Ur Still Gay"
........................__
..........._______ |__\__
..........|__(O)______(O)]
72mistressc10 is offline   Reply With Quote
