07-26-2009, 05:47 PM | #1 |
Old Skool Club
Seat Belt Solutions -- Anyone use?
Here's a link to www.seatbeltsolutions.com from their truck page. Only black is available for bench seats at this time, so just curious as to whether anyone has ever used them?
http://seatbeltsolutions.com/_wsn/page7.html
Member Nr. 2770 '96 GMC Sportside; 4.3/SLT - Daily driven....constantly needs washed. '69 C-10 SWB; 350/TH400 - in limbo The older I get, the better I was. Last edited by ChevLoRay; 07-26-2009 at 05:47 PM. |
07-26-2009, 07:52 PM | #2 |
Restoration Virgin!
Re: Seat Belt Solutions -- Anyone use?
Haven't used them, but would be interested in some if they are priced right??.....saw some 3 pt universal belts on Fleabay for $85 shipped....for what it's worth!!!
Geoff with a G 1968 Chevy C10 SWB The Mistress 1972 Custom Deluxe C20 Suburban A Suburban Named Isabella 1966 Ford Mustang Mama's High School Graduation Present |
07-26-2009, 08:26 PM | #3 |
Have not used them, but make sure you go with 3 point belts. These look like they do not bolt into the factory holes. You will have to drill holes to mount the retractors. The reason the one's from Brother's and others are so expensive is that they do not require drilling and merely bolt into the stock holes using custom made application specific brackets. I used an expensive custom made kit for my 67 Camaro and it was easy to install and feel very safe. For my 68 C10 I am temporarily using junk yard 3 point belts from a Volvo and made my own floor brackets. However, I will eventually go with a custom kit like Brother's sells once I get the truck 100% done.
07-26-2009, 09:10 PM | #4 |
Between Trucks...
Here's the ones I'm running: https://www.classicparts.com/prodinfo.asp?number=28-071
Had to take a dremel to them a little bit to work with the factory bolts. Buckle side is a tad short if you have to move your seat forward, but I'm 6' tall so not a problem.
Beat it to fit, Paint it to match... |
07-26-2009, 09:59 PM | #5 |
Old Skool Club
Juliano's has 'em too. But I've also read of folks using S-10 shoulder harnesses. Reckon it comes down to what you can fit and be comfortable.
Member Nr. 2770 '96 GMC Sportside; 4.3/SLT - Daily driven....constantly needs washed. '69 C-10 SWB; 350/TH400 - in limbo The older I get, the better I was. |
07-27-2009, 01:40 AM | #6 | |
70 Chevrolet=Obsession
I'm Just like my truck. Old, Ugly and Grouchy. Except my truck starts easily in the morning and doesn't smoke! IT'S NOT EASY BEING GREEN! -Kermit the frog 1970 Chevrolet C-10 Longbed Stepside : 350, Muncie M20, 3.08 GM corp. positraction Forest green exterior/light green interior(Where all my money goes) 1996 Toyota Corolla (Parts runner) |
