07-28-2009, 10:49 AM | #1 |
Loving the Jimmster
Radiator Assistance
Working on a 67 c10, had a 283 replaced with 350 out of a 1968. Went to use the 68 fan shroud and it wont fit?? 67 never had one. The 68 is stock as far as i can tell. So i grabed the 68 rad, and it is to long for the bottom rad support? Is there a differance in the 68 and 67 radiator support??
07-28-2009, 11:10 AM | #2 |
Loving the Jimmster
Re: Radiator Assistance
Ok checking it further, there seems to be two sets of holes for the radiator on the passenger side. What is the differance? 67 is a 1/2 ton 68 is a 3/4 ton?
07-28-2009, 11:29 AM | #3 |
The size of the raditor differs with the engine & options. I know my standard 2 core shroud does not fit my 4 core replacement radiator. I had to find a shoud from a HD or 3/4 core radiator. That may be the difference you are seeing. I am not sure or aware of a difference between years.
07-28-2009, 11:35 AM | #4 |
Resident Curmudgeon
I6 (narrow) vs V8 (Wider). That is why 2 set of mount holes on one side of core support
Currently on or near the homestead: 67 Chevy SWB 2WD stepside 350/3 on tree (Pat's) 67 GMC SWB 2WD Fleet 402/auto (Brian's under construction) 67 Chevy 3/4 ton 2WD 402/auto (Business Hauler) 67 Chevy 1 ton dually 2WD 396/4 speed (Former business hauler, Needs TLC) 68 Chevy 1/2 ton Suburban 2WD 250 six/3 on tree (Brian's Needs TLC) 70 Chevy 3/4 ton 4WD 350/4 speed (Pat's - Disguised as a 68 GMC) 71 Chevy SWB stepside (Crushed by tree - parts donor) 72 Chevy 3/4 ton 4WD (Parts donor) 72 Chevy 3/4 ton 4WD Suburban (Parts Donor) 72 GMC 3/4 ton 4WD 292 six/4 speed (Mine - Disguised as a 67 GMC) 81 GMC 4WD Dually Dump Body 350/4 speed (Business Hauler) 82 Camaro Z/28 355/Super T-10 (Pat's toy) 93 Caprice 9C1 (Brian's Cop Car) 02 Toyota Camry (Reliable but a souless steel and plastic hulk) 2011 2SS RS Camaro M6 Factory Hurst Shifter Maybe I need to sell some of this crap Yet another Bozo with a sawz-all |
07-28-2009, 11:41 AM | #5 |
Loving the Jimmster
ok that makes sence since the 67 had a v-6 originally. So with a 350 should you use the bigger rad? And can you get the bottom rad supports, and just change it over the next holes?
Thanks for the input |
07-28-2009, 11:54 AM | #6 |
Resident Curmudgeon
Drill out the rivet and move it over and bolt back in. I just did this on a 67 rad support that was originally and I6 and is now cooling a big block 402 with a 4 core radiator. Note, I had to "modify" (read hack )the lower supports for the 4 core and locate some 4 core upper hold downs since the originals were designed for the narrower 2 core
Currently on or near the homestead: 67 Chevy SWB 2WD stepside 350/3 on tree (Pat's) 67 GMC SWB 2WD Fleet 402/auto (Brian's under construction) 67 Chevy 3/4 ton 2WD 402/auto (Business Hauler) 67 Chevy 1 ton dually 2WD 396/4 speed (Former business hauler, Needs TLC) 68 Chevy 1/2 ton Suburban 2WD 250 six/3 on tree (Brian's Needs TLC) 70 Chevy 3/4 ton 4WD 350/4 speed (Pat's - Disguised as a 68 GMC) 71 Chevy SWB stepside (Crushed by tree - parts donor) 72 Chevy 3/4 ton 4WD (Parts donor) 72 Chevy 3/4 ton 4WD Suburban (Parts Donor) 72 GMC 3/4 ton 4WD 292 six/4 speed (Mine - Disguised as a 67 GMC) 81 GMC 4WD Dually Dump Body 350/4 speed (Business Hauler) 82 Camaro Z/28 355/Super T-10 (Pat's toy) 93 Caprice 9C1 (Brian's Cop Car) 02 Toyota Camry (Reliable but a souless steel and plastic hulk) 2011 2SS RS Camaro M6 Factory Hurst Shifter Maybe I need to sell some of this crap Yet another Bozo with a sawz-all Last edited by CPNE; 07-28-2009 at 11:55 AM. |
07-28-2009, 11:56 AM | #7 |
Loving the Jimmster
Sweet thats what i am going to do!!! So many little changes on these darn things almost makes me crazy
