Re: LMC rear gas tank install
I bought the same tank from LMC with no instructions and called them. They said there is no instructions because it is a custom application on our trucks. YOU have to find a way to do it. I cut 1" tubing as spacers to lower the tank away from the sill and bolted it to my frame and then also used the straps from front to rear using "J" bolts through the rear cross member. I think I like the left to right better after seeing those pics.
