Old 03-28-2003, 04:19 AM   #151
67c-20
i don't know how rare it is but in all of my serarchs i have only seen one rear axle like the one in my 68 gmc. it had a 10 bolt cover 6 lug wheels which is not that rare but mine had studs that came from the outside of the axle towards the pumpkin. every one i have ever seen has carriage style bolts that have the studs going out towards the wheels. if you ever had a wheel bearing go out in one of these like i did you will know it because your whole axle, wheel, and brake drum leave the truck. mine went into the woods in the middle of the night.
67 k-20 w/327 and a 3speed and 4.57 rear with 17 inch split rims and 9 inch wide rubber(is my current project)
73 blazer 6 inch all spring lift 350/350 with crappy 3.08 gears and 35 inch bfg tires. just put out 135 hp to the wheels on the dyno.
54 chevy delray .060 over 250 i-6 which was taken from my first truck(68 gmc). it is next in line for a rebuild
67c-20 is offline   Reply With Quote
Old 03-29-2003, 12:39 AM   #152
Dreaminator
Dreaminator
Anyone have any more pixs or dimensions of the inside cargo hooks?
The Dreaminator
Daily Driver 1971 Cheyenne 10 Lwb Tilt/Tac 402 .030 TH400.
Dreaminator is offline   Reply With Quote
Old 03-30-2003, 07:35 PM   #153
Gee_Emm
I found one of the pages scanned from the accesories book.
Gee_Emm is offline   Reply With Quote
Old 03-31-2003, 02:34 AM   #154
casey
casey's Avatar
I'm not sure how rare this is, I was talking to a guy with a swb step side, he said the clove box build sheet said his truck was a 6cylinder with a 400 turbo alittle over kill on the tranny don't you think, it also had heavy duty coils added from the factory, he said it might of been some type of delivery truck
casey is offline   Reply With Quote
Old 04-01-2003, 10:45 AM   #155
slomotion
Old Duffer
slomotion's Avatar
Hey guys, I'm a new member although I've been hanging with you for a few months. I've been dubbing around with old trucks for a long time....wish I had a few of them back...hind-sight and all that stuff.
Anyhow, I just brought home a '68 C20 SWB factory 3/4 ton rack body dually. 292 six, w/4spd, radio delete, speedo and fuel gauge. The rest are "idiot" lights. The truck has 26K original miles and no rust. It has what appears to be Chevy clearance lights (based on the photo's in an earlier post) although the glove box door sticker doesn't mention them.
I don't want to do any cutting on this truck, but I'd like a better array of gauges. Would it be sacrilege to modify a glove box door ( cut a clearance for the steering column, punch holes for the gauges and put in a set of after-market gauges?)That way, if I wanted to go back to bone stock I wouldn't have hurt anything
'68 Short C20 Flatbed Dually
w/ 292 4bbl, Langdon cast headers,
and WC T5 trans.
'81 G10 Shorty Van
"Good judgement comes from experience, and a lot of that comes from bad judgement." Will Rogers
"Under promise, then over achieve."
slomotion is offline   Reply With Quote
Old 04-01-2003, 11:18 AM   #156
CPNE
Resident Curmudgeon
CPNE's Avatar
Slomotion, welcome from NH.
Pretty much the opinions here are "do what you want, it's your truck".
If it were me I'd find a used full guage cluster and substitute in the aftermarket gauges you want to use rather than to do the glove box thing.
Try posting your question on a new post you create (New Thread" button), you'll get a lot more response.
BTW, factory clearance lights did not appear until 69 and that style is easilly identifiable by the raised "hockey puck" mounting areas in the cab roof. What you have is dealer installed and would not be on the glove box build sheet.
Currently on or near the homestead:
67 Chevy SWB 2WD stepside 350/3 on tree (Pat's)
67 GMC SWB 2WD Fleet 402/auto (Brian's under construction)
67 Chevy 3/4 ton 2WD 402/auto (Business Hauler)
67 Chevy 1 ton dually 2WD 396/4 speed (Former business hauler, Needs TLC)
68 Chevy 1/2 ton Suburban 2WD 250 six/3 on tree (Brian's Needs TLC)
70 Chevy 3/4 ton 4WD 350/4 speed (Pat's - Disguised as a 68 GMC)
71 Chevy SWB stepside (Crushed by tree - parts donor)
72 Chevy 3/4 ton 4WD (Parts donor)
72 Chevy 3/4 ton 4WD Suburban (Parts Donor)
72 GMC 3/4 ton 4WD 292 six/4 speed (Mine - Disguised as a 67 GMC)
81 GMC 4WD Dually Dump Body 350/4 speed (Business Hauler)
82 Camaro Z/28 355/Super T-10 (Pat's toy)
93 Caprice 9C1 (Brian's Cop Car)
02 Toyota Camry (Reliable but a souless steel and plastic hulk)
2011 2SS RS Camaro M6 Factory Hurst Shifter
Maybe I need to sell some of this crap
Yet another Bozo with a sawz-all
CPNE is offline   Reply With Quote
Old 04-01-2003, 12:07 PM   #157
AndrewDT
AndrewDT's Avatar
Hey there, CPNE,
Did you ever come up with pics of your luggage carrier? I'd like to see what a vintage one looks like. Thanks!
AT
'72 Suburban 4X4
"Save the Earth, kill yourself"
AndrewDT is offline   Reply With Quote
Old 04-01-2003, 12:31 PM   #158
CPNE
Resident Curmudgeon
CPNE's Avatar
I'll post dome pics for you and ckhd when I can get them.
Old 04-01-2003, 08:07 PM   #159
Gee_Emm
I wouldnt do cutting on that, but its your truck
You can get a factory style guage package with
Speedo, fuel, oil pressure, battery and temp gauges
or
Speedo, fuel, oil pressure, battery, tach and temp gauges
or
Speedo, fuel, oil pressure, battery, tach, vacuum and temp gauges
or
Speedo, fuel, oil pressure, battery, tach, air pressure(wouldnt be much use to you though) and temp gauges
Do you have any pictures of this truck, I would love to see it.
Old 04-02-2003, 02:27 PM   #160
slomotion
Old Duffer
slomotion's Avatar
Gee emm, thanks for the in-put. I agree, keeping the dash looking stock is a better way to go.
I'll get a few pics up on another thread when I get a couple. I have a digital camera but haven't figured it all out yet....
and WC T5 trans.
'81 G10 Shorty Van
Old 04-02-2003, 03:37 PM   #161
68Custom
Hammer On!
68Custom's Avatar
IMO, i would say the rarest option would be the 50th anniversary package, it only came one out of the running 6 years total. and what was the production number for all of these around? i must admit, i am impressed with all of these cool finds as far as the options go
Aaron
1968 C20
Inline 6 250
SM465 4 speed
1968 K10
Inline 6 250
SM465 4 speed
68Custom is offline   Reply With Quote
Old 04-02-2003, 04:56 PM   #162
Rod
How about right hand drive trucks for European markets? Rare enough Id say... I've never seen one.
Senior active founding member.
70 3/4 ton GMC Suburban 4x4 250/4 spd.
71 1/2 ton Suburban Chevy 4x4, 350/350
72 Chev 1 ton tow truck 402BB w/Holmes 440 wrecker on propane
2005 FLSTSCI Harley Springer
85 FXSB Harley Lowrider
72 Triumph 650 Bonneville 5spd
"Poor people don't have hobbies" Quote from wife.
Rod is offline   Reply With Quote
