Old 07-29-2009, 05:26 PM   #1
Moax
Moax's Avatar
Re: Engine mount question
Okay, here are some pictures.
Moax is offline   Reply With Quote
Old 07-29-2009, 06:23 PM   #2
padresag
http://www.persh.org/pickup/perches.htm
scroll down through this
ron
padresag is offline   Reply With Quote
Old 07-29-2009, 07:22 PM   #3
Moax
Moax's Avatar
Smile Re: Engine mount question
Thanks guys.
Chevy Fleetside, watch out, I might take you up on that offer. Actually, I think I might be okay with the 67-72 perches. I'm going to try them.
And thanks for the link Ron.
I'll let you guys know how it works out.
Old 07-29-2009, 08:45 PM   #4
markeb01
Senior Enthusiast
markeb01's Avatar
The torsion bar frame is actually 1 inch shorter in vertical height than the later frame in the area where the motor mount towers attach. On mine I used the 67-72 towers with 1" solid steel spacers between the frame and the upper mounting bolt holes. The only photo I have shows the mock up using a 1" aluminum lowering block. This was replaced with 1" thick steel before the engine install was complete.
I bolted the motor mounts to the engine, and the towers to the mounts. Then the engine was lowered into the compartment until everything touched, the bolt hole locations were marked, the engine pulled and the holes drilled. It's worked fine for close to 20 years. Good luck.
URL=http://img194.imageshack.us/i/a0029e.jpg/][/URL]
