07-27-2009, 10:28 PM | #1 |
coil cut off?
really want to lower my truck got no money
so im gonna cut my springs i know i know dont do it but im gonna. has anyone done this how many coils would i have to cut off to give me a good 2/4 maybe 3/5 drop? |
07-27-2009, 10:35 PM | #2 |
its all about the +6 inches
Re: coil cut off?
cut off one coil up front, thats good for a 2 to 3 inch drop.
you cant cut the rears, they need the pigtails on both ends. |
07-28-2009, 10:02 AM | #3 |
Re: coil cut off?
In a 67 I used to have, 2 coils in the front = 6". I put 2" blocks in back and then torched em for a couple more. Not the right thing to do but we were all "young and dumb" once. (no offense!)
Turp Mcspray New life for an old 2wd, farm blazer http://67-72chevytrucks.com/vboard/s...d.php?t=505987 My Blazer build http://67-72chevytrucks.com/vboard/s...d.php?t=342299 |
07-28-2009, 11:11 AM | #4 |
Re: coil cut off?
Longhorn Man, when you say 2-3 inches does that just vary by the age or use of the spring? I am going to put in 2 inch lowering blocks in the back and would like get as close to a 2 inch drop in the front as possible. I guess I should cut less than one coil and reinstall them and check? Thanks for your help.
07-28-2009, 04:19 PM | #5 |
Re: coil cut off?
all kinds of variables, the age of the springs, the p/n of the springs (there were more than 3) the amount of abuse they have had... you may be at a 1 or 2 inch drop right now and don't even realize it.
07-30-2009, 12:25 AM | #6 |
Re: coil cut off?
Well I am sure I'm going to cut them
What about neagative camber You ajust for this by shimming the upper control arm right? Going for a 3/5 |
07-30-2009, 06:07 AM | #7 |
Watch out for your cornhole !
Re: coil cut off?
Like Andy said, you cannot cut the rears.
07-30-2009, 10:31 AM | #8 |
Re: coil cut off?
I've cut one coil and want more so I've been searching for info on cutting but find I can only cut one or two completely off because of the way the spring keys in. My question is has anyone secessfully cut a quarter or half ring out?
Thanks |
07-30-2009, 11:00 AM | #9 |
Re: coil cut off?
I know I'm getting 5" drop spings from cpp and an ajustable trac bar
Will I need four new lower shocks? But cutting the front ones I want a good 3/5 drop One coil should do this? Will I have to ajust my camber by shimming the upper control |
07-30-2009, 11:16 AM | #10 |
Re: coil cut off?
yes ... you will need to have the front re-aligned once the coil is cut and reinstalled ... most times it will require shims to reset the camber
07-30-2009, 11:16 AM | #11 | |
67-72 parts collector,…
Re: coil cut off?
1/2 coil cut= 1" of drop. (this can vary between vehicles) You can correct the camber issues with shims,... but I would suggest getting a front end alignment to address caster and toe also.
Keith Convert to disc brakes. http://67-72chevytrucks.com/vboard/s...d.php?t=444823 Last edited by lolife99; 07-30-2009 at 11:17 AM. |
07-30-2009, 04:02 PM | #12 |
Re: coil cut off?
i cut 1/4 coil on the front springs on the burb. No issues at all.
07-30-2009, 04:54 PM | #13 | |
Re: coil cut off?
I agree 1/2 coil cut = 1"drop , I have cut 1 1/2coils for a 3" drop many times with great results. buy new ones for the rear(5 inch)
C/10 Rene 1966 Short Fleet "The Hag" 1967 CST Short Fleet "Dark Poly" 1971 Short Fleet 1970 Jimmy Custom 2 WD "Golden Ticket" 1972 Blazer 2 WD "Retro Blaze" |
