Old 07-30-2009, 10:54 PM   #1
okblazer
speedometer
I have a 71 Blazer. The speedometer is not working. I removed the cable and turned it and the needle on the speedometer moves. The cable is attached to what seems to be an offset gear box which seems to be ok, then that attaches to the transmission. I pulled the drive gear from the transmission and it looks good ( almost dropped in the transmission case). Any body got any ideas?
okblazer is offline   Reply With Quote
Old 07-30-2009, 11:05 PM   #2
BAGNDRAGIT
Just Not Low Enough!
BAGNDRAGIT's Avatar
Re: speedometer
broken cable?.....spin one end, find a pair of eyes to help you and see if the other side spins..
maybe its not engaging...
NEED ELECTRICAL HELP? ASK ME!
67-72 Full Wiring Diagrams
Lots Of Info, TAKE A LOOK
1967 Chevy C-10 Shortbox Bagged 327 4spd
Previous:
1971 Chevy C-10 Short Sep I6 Auto (Traded)
1973 Chevy C-20 *THE REDNECK BATTLE TRUCK*
2001 Chevy Silverado 2Dr 5.3L Shortbox. R.I.P.
1969 Volkswagen Bug
This is my first meeting, I have a horsepower problem.
BAGNDRAGIT is offline   Reply With Quote
Old 07-31-2009, 02:30 AM   #3
old man jimmy
Re: speedometer
If you spin the bottom side of the cable & the speedo needle moves. Next I would do away with your little offset do-dad, and run just your cable. If speedo works that way, you know what it is. I don't even know what they are on their for. I took mine off over 30 years ago trying to match gears to tires.
old man jimmy is offline   Reply With Quote
