Old 07-03-2009, 12:37 PM   #651
MacAttack
283 Drama Queen
MacAttack's Avatar
Re: The 283 Rebuild Begins
Originally Posted by 1964C10 View Post
Will a TH350 bolt up to an L6 without too much problems?
Perfectly. Unfortunately - when I let the 6 go I forgot to take the flex-plate off (just lazy) and had to buy one from Jeg's for the 283.
A Homer moment.
Mac.
For about 12 years of my adult life I had a severe speech impediment.
My ex-wife never let me get a word in edgewise.
MacAttack is offline   Reply With Quote
Old 07-04-2009, 12:55 PM   #652
justcuz
justcuz's Avatar
Hey Mac, good to hear you got the tan running. The thread is entertaining as can be! Did I remind you about drilling the bleed hole in the thermostat lip? If not sorry about that. A 1/4 hole in the lip lets the air bleed out and if you keep the cap off and the coolant level about an inch below the top of the radiator, it usually will not puke over the top when the thermostat opens.
Do you have a spin on oil filter? If so remember the oil change interval for that new engine. I think I posted it for you somewhere in here. If not let me know, I'll repost it. Lastly will you have this back in time for the Brothers Truck Show this year. If not you should go anyway, take your son and grandson. It is full of a lot of cool old Chevy trucks. Plus you may meet some board members there.
justcuz is offline   Reply With Quote
Old 07-06-2009, 09:40 AM   #653
MacAttack
283 Drama Queen
MacAttack's Avatar
Thanks, Man - it’s taken way too long to get to this point, but I’m glad I finally made it.
Went with the Milodon thermostat, 160 degree, high-flow and it’s got a bleed ‘dimple’. After I threw that P.O.S. Chinese thermostat as far as I could and installed the real one - everything worked perfectly - coolant wise.
Yes I have a spin-on oil filter (bought the NAPA adapter kit) and yes I need a refresher on the oil change interval.
Can’t make the show, as my mom’s coming in Thursday afternoon from Phoenix for the grandson’s birthday weekend and I’ll be booked through Monday. Bummer.
Mac.
Old 07-11-2009, 11:11 AM   #654
justcuz
justcuz's Avatar
First oil change and filter, right after cam break in ,(so when you get it home)
Next at 500 miles
Then at 1000 miles
Next at 2000 miles
Again at 3000 miles
Then every 3000 there after.
I personally would use the recommended amount of oil additive for the first 1000 miles at least, until the rings seat. After that you should be OK, but you could add 4 to 8 ounces with each oil change if you are concerned about lubrication.
Old 07-12-2009, 12:57 PM   #655
VDOG
Grand PooBaa Member
VDOG's Avatar
My 283 after installing a new intake. It was built 11 years ago, other than changing the water pump, its run flawless. Now its getting a lil tired, getting some blowback, so it will be replaced for a 350 for more torque, then the 283 will be rebuilt and shellved for a 62 to 65 nova project, someday.
VDOG is offline   Reply With Quote
Old 07-12-2009, 01:40 PM   #656
jgh64pkup
Sunburst C10!!!
jgh64pkup's Avatar
i think you radiator hose is a little kinked
Gage
1967 C10 Shortbed Stepside
jgh64pkup is offline   Reply With Quote
Old 07-12-2009, 04:42 PM   #657
VDOG
Grand PooBaa Member
VDOG's Avatar
LOL!! Yeah that was a while ago, its better now.
Old 07-28-2009, 10:15 AM   #658
MacAttack
283 Drama Queen
MacAttack's Avatar
Piston Ring Seating Myth Time:
The truck is coming home after I leave work at 5PM Friday, 7/31. The shop is 1.5 miles from my house - which should allow time to get 'The Tan' up to operating temperature.
If it's actually ready for driving home I plan on taking her down some small hills (about 75 feet in elevation) and mashing the crap out of the accelerator (once I'm sure the brakes function correctly) and get up to about 70 mph and slam on the brakes as hard as I can (drums all around with power booster), go back up the hill and repeat the process 3-4 times, and/or get arrested for speeding in a 35 mph zone.
The Myth?: It seats the rings before the honing cross-hatch has worn off.
......or not?
Old 07-28-2009, 07:19 PM   #659
protrash64
Resistance is Futile
protrash64's Avatar
Sounds like it oughta knock any glaze off your brake shoes!! I've heard just about everything at this point....''take it easy for the first 500''....''dont drive at a constant speed''.....''drive it how you would normally''. I couldn't tell ya.
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash
64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban
66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852
STRENGTH/DETERMINATION/MERCILESS/FOREVER
.......posted via stationary device
protrash64 is offline   Reply With Quote
Old 07-28-2009, 07:34 PM   #660
shrunken66stroker
shrunken66stroker's Avatar
Make sure the e-brake works too. Just in case. You would have to coast around the block quite a few times to slow down from 75.
shrunken66stroker is offline   Reply With Quote
Old 07-31-2009, 02:34 PM   #661
MacAttack
283 Drama Queen
MacAttack's Avatar
Five hours to pick the old girl up..................maybe................
In the mean time, check out the cams we're grinding this morning. ($5k each)
(no customer name, but it kind of rhymes with):
Old 07-31-2009, 03:02 PM   #662
MacAttack
283 Drama Queen
MacAttack's Avatar
and.....
Old 07-31-2009, 03:04 PM   #663
MacAttack
283 Drama Queen
MacAttack's Avatar
and finally.......(more money in this single piece than my entire drive train)
Old 07-31-2009, 03:24 PM   #664
mike73
mike73's Avatar
What kind of cam are you putting in it? I would suggest staying mild, something like a HO 305 Camaro cam. Ask the machine shop, but those small engines do not like a lot of cam, won't make much vacuum for power brakes if you do. HO 305 cam is like 403 in and 415 ex. I forget the duration and lobe seperation, it is slightly bigger than a stock 350 cam which is 390 in and 410 ex. Are you running a 2 barrel carb? How do you crack an intake manifold? Does this guy build hobby stock race engines? Old stock Chevy 2BBL intakes are worth bank to these guys for some reason. I swapped 3 of mine for some cast iron 4BBL intakes for Qjets and the guy was practically overjoyed to get them. Not worth much to me, I would rather have the Qjet and drive the primaries most of the time and still have the ability to tromp on it if needed.
I think they like em for the TBI swaps if Im not mistaken?
mike73 is offline   Reply With Quote
Old 07-31-2009, 05:15 PM   #665
joe231
joe231's Avatar
Cool...
where do you work?
CHEVY ONLY
joe231 is offline   Reply With Quote
Old 07-31-2009, 11:22 PM   #666
protrash64
protrash64's Avatar
Hey, how did you post pics from today?
Old 08-02-2009, 01:05 AM   #667
Captainfab
60-66 Nut
Yeah what's up with that?.....couldn't be could it?....did Mac get a digital camera?
Old 08-03-2009, 07:06 AM   #668
4dranch
Shloooooong bed member #2
4dranch's Avatar
David,
Daughters 66 truck:
http://67-72chevytrucks.com/vboard/s...d.php?t=484601
Learning to drive a 3 on the tree:
http://www.youtube.com/watch?v=CcCMvRgBo1Q
4dranch is offline   Reply With Quote
Old 08-03-2009, 10:10 AM   #669
MacAttack
283 Drama Queen
MacAttack's Avatar
Originally Posted by joe231 View Post
Cool...
where do you work?
Machine / Grinding / Tooling - Job Shop.
Boss’s Sony - old school, with a 3.5" floppy.
Not a chance!
BTW - no truck yet: Electrical gremlins.
Old 08-05-2009, 04:05 PM   #670
MacAttack
283 Drama Queen
MacAttack's Avatar
Talked with my transmission guy last night - apparently the PO (a friend's son) had put posi in this truck and the rear end may not be from a 65'. Asked if I wanted to put the money into overhauling it and I agreed immediately.
The new gears will have the 283 turning 2,450 @ 65 mph because of the short (60 series) T/A Radials, which is just fine - in my book.
Hopefully I'll get to actually drive this truck some day.
Mac.
Old 08-05-2009, 04:14 PM   #671
MacAttack
283 Drama Queen
MacAttack's Avatar
I want my schlong! (bed)
Old 08-05-2009, 04:55 PM   #672
70 Suburban
Rods
Originally Posted by macattack View Post
i want my schlong! (bed)
if you dont mind can you never post that pic again...wow
Just keepin it simple.
1965 C-10 Ext cab build. 350??(Does it count at 2 truck if I had to cut one up?)
1966 C-10 lwb 283 auto
1970 Suburban in pieces
1971 Blazer 4wd....restore someday. all factory CST
1972 Blazer 4wd parts truck still a roller
1972 GMC Sierra Grandee
1998 Chevy ext driver.
2005 F**D the wife drive...(cant fix women)
70 Suburban is offline   Reply With Quote
Old 08-05-2009, 05:00 PM   #673
MacAttack
283 Drama Queen
MacAttack's Avatar
* gee - if I had a nickel for every time I've heard that.
Mac.
Old 08-05-2009, 07:38 PM   #674
protrash64
protrash64's Avatar
Mac.
.......no doubt!!
Old 08-06-2009, 06:48 AM   #675
4dranch
4dranch's Avatar
David,
Daughters 66 truck:
