Old 08-02-2009, 06:01 PM   #1
jbristo67
resident oilfield trash
jbristo67's Avatar
Need Help C notching my truck
I just got my old coil springs off and there is a plate rivited to the frame. Is there any problem with just cutting the rivets off and doing away with the plate
1967 SWB C10 396/400 factory air
factory tach (sadly had to send to a new home)
1986 Honda 70 Fourtrax
1991 Chevrolet K5 blazer 2wd
1982 Mastercraft Pro Star 190 Stars and Stripes
2002 Chevrolet Tahoe
2011 Nissan Armada
jbristo67 is offline   Reply With Quote
Old 08-02-2009, 06:18 PM   #2
crasten123
crasten123's Avatar
Re: Need Help C notching my truck
Not sure what you mean. I had to grind off the rivets. I then used a template to cut out the notch. After, it was just a matter of drilling a few extra holes to bolt on the c-notch plate. I don't remember seeing any plate. I actually welding around the notch in after bolt just to help support it better (not sure if it was necessary).
[B]72 Cheyenne SWB
crasten123 is offline   Reply With Quote
Old 08-02-2009, 06:36 PM   #3
jbristo67
jbristo67's Avatar
This is the plate I am talking about. I had planned on just chopping it off but This side has my brake hose coming out of it. I know the bottom rivets have to go but does this plate go too or does it stay.
2011 Nissan Armada
Old 08-02-2009, 06:49 PM   #4
ebfabman
Don't mean to be insulting, but are you sure you're putting the notch in the right place?
ebfabman is offline   Reply With Quote
Old 08-02-2009, 06:58 PM   #5
jbristo67
jbristo67's Avatar
What you mean it doesnt go under the cab.
2011 Nissan Armada
Old 08-02-2009, 07:05 PM   #6
70k52wd
Blaze-Air
70k52wd's Avatar
NO, do not cut the rivets or the plate off. It stays. You will wind up having to trim the plate to fit the notch.
Click on my link in my sig. I'm sure you will see what needs doing. The notch will sit exactly where your old bump stop bracket is. It will be cut out.
70k52wd is offline   Reply With Quote
Old 08-02-2009, 09:22 PM   #7
jbristo67
jbristo67's Avatar
Thanks man NIce blazer. Now I just have to go bolt those plates back on
2011 Nissan Armada
Old 08-02-2009, 10:32 PM   #8
crasten123
crasten123's Avatar
Yes...i believe that's correct. The plate stays on...teh outer portion of the plate the sticks outside the frame will need to be trimmed. After , the c notch should fit right over it.
[B]72 Cheyenne SWB
