Old 04-03-2003, 11:42 AM   #1
bpmcgee
bpmcgee's Avatar
Help! Weird failure
Last night I was driving home in the 71 blazer. I was smelling fuel pretty strongly. Cruising along at 40 mph, the engine started stuttering badly. When I pulled up to the next stop sign, the engine just died right out and wouldn't restart.
When I checked clear fuel-filter right in front of the carb, there was no fuel. I figured "Dead fuel pump." So, I had it towed to my house.
This morning, I went outside to work on it. I turned it over, it quickly filled up the fuel filter and started right up!
Can a mechanical fuel pump behave this way? I'm more suspicious of cracked rubber fuel line someplace -- accounting for the strong smell of fuel while the fuel filter was empty.
Any ideas?
Thanks!
Brian
bpmcgee is offline   Reply With Quote
Old 04-03-2003, 12:37 PM   #2
O'l Buck
Recovering Truck Driver
O'l Buck's Avatar
My guess would be a rubber line cracked or collapsed, but it could be the diaphragm in the fuel pump.....there is a weep hole for the fuel to come out of it the diaphragm goes.
67 K-20 350, SM465, Eaton rear, 4.56 no spin option
00 Dodge 2500 4x4, 24V cummins, 5 speed
Chad
South Central Nebraska
O'l Buck is offline   Reply With Quote
Old 04-03-2003, 12:43 PM   #3
Blazer1970
Blazer1970's Avatar
I would suspect the fuel pump. Make sure it didn't fill your crankcase up with gas.
Blazer1970 is offline   Reply With Quote
Old 04-03-2003, 01:27 PM   #4
JimKshortstep4x4
Talking
I am kind of on the same line as Blazer1970. It sounds like you were getting excessive fuel. I would suspect the float/needle valve getting stuck and causing extra fuel to be pumped into your carburetor. Flooding would cause the gas smell and the stalling.
Jim
Old 04-03-2003, 02:20 PM   #5
Blue Beard
Blue Beard's Avatar
I would suspect the hoses, depending on if they look very old.
I had that problem once. Started at the carb, replacing everything. Only to find it was the rubber hose between the gas tank and the frame. Had a deteriated hose and was acting like a flapper valve shutting off the gas.
1970 Chev CST
2003 Harley Fatboy
1975 Chevrolet Step Van
1956 Chev Bel Air
1977 Blazer 2WD For Sale $3000.00
1978 Blazer 2WD For Sale $7000.00
1978 Silverado
2005 Monte Carlo
Blue Beard is offline   Reply With Quote
Old 04-03-2003, 06:01 PM   #6
cdowns
cdowns's Avatar
i'd go for the hoses
Old 04-03-2003, 09:53 PM   #7
Hooter
My other Love
Hooter's Avatar
sometimes the fuel pump will work, stop, work again, stop, Pain in the butt, I ended getting fed up and just replacing the damn thing
Castlegar B.C.The great white North (Canada Eh!)
Hooter_5@hotmail.com
First generation Monte Carlo club
pictures of my life
Hooter is offline   Reply With Quote
