Re: Wheel Problems
thats normal you do need to replace the studs with longer ones
aluminium is soft and any mounting flange made thinner would pull the nuts right through the rim check out big rig rims those are about 1/2 inch thick. its a bit of work to clear everything around it to get the studs out ....... european cars are a little eazier since they use bolts
i got a job again and having fun at it too idea's for the trucks and the order of things to do are taking shape and get closer to being realized , a few more months and i be able to start building for real i complete 2 of the trucks intoo running fashion one custom and one basicly stock the thirth will be sacrificed for parts Last edited by watahyahknow; 08-07-2009 at 01:52 PM. |
