Old 08-07-2009, 05:17 PM   #1
powerdriver 1958
Kid's Mechanic
powerdriver 1958's Avatar
Re: hard to start when hot!
Two of my trucks would vapor lock after header installs.One big block 76 and the truck I use for muding.The fuel line runs inside the right frame rail just Inches from the headers.I moved the fuel line to the outside of the frame.
powerdriver 1958 is offline   Reply With Quote
Old 08-08-2009, 10:01 AM   #2
68 TT
Still plays with trucks
68 TT's Avatar
Chances are the headers are hotter than they should be because the engine is running lean.
If you haven't tuned the carb for the headers and intake swap so you have the proper air / fuel ratio then you will have higher than normal exhaust gas temperatures which will make the headers hotter than they should be.
This is causing the extra hot headers to heat soak the starter and heat up the air in the engine compartment more than it should. You may have a combination of a hot starter and a vapor lock issue because of it.
Get an air / fuel meter and jet the carburetor to match your combination before you go changing any parts.
68 TT is offline   Reply With Quote
Old 08-12-2009, 02:23 PM   #3
jchav62
1962 C-10
jchav62's Avatar
That's a great idea! Never thought of that.
Hey Volker! Have you tried anything? Still having issues?
Joseph Chavez
"See the USA in a Chevrolet!!"
......................_____
.........________//__{\_____
,,,,,,,/__(O)___//___/__(O)_/
1962 C10 Shortbed Fleetside 327/th350 GV overdrive
1974 C10 Longbed Fleetside 350/th350 "The Trash Truck"
1999 Chevy 2500 OBS, Longbed 5.7/4L80E 4x4
2015 GMC Sierra SLE 1500 4x4
jchav62 is offline   Reply With Quote
