08-07-2009, 01:58 AM | #1 |
DJM Flip Kit Question
The $85 Djm flip kit on summit's web site says that it doesn't have shock extensions included but they're clearly in the pic. can anyone please clarify if they're in the kit for me? Thank you.
http://www.summitracing.com/parts/DJM-FK1024-5/ |
08-07-2009, 03:35 AM | #2 |
6.0 powered square
Re: DJM Flip Kit Question
there not in the kit
Aaron 1980 c-10 short bed lowered, cammed 6.0, 4l80e 3600 stall, smp tune, wilwoods, and flames best time so far best et 7.86 @87 on motor 7.57 90 on a 75 shot Build http://67-72chevytrucks.com/vboard/s...d.php?t=283326 |
08-07-2009, 10:05 AM | #3 |
Uh, yes they are. That is the exact kit I used. See the link in my sig.
- Greg Last edited by 454HO; 08-07-2009 at 10:06 AM. Reason: add pic |
08-07-2009, 10:35 AM | #4 |
hey anyone got a pick with this kit installed?
08-07-2009, 10:40 AM | #5 |
- Greg |
08-07-2009, 11:28 AM | #6 |
ok another question....i got the 2 inch shackles in the back...if i were to get this kit what would make the front even?
08-07-2009, 12:34 PM | #7 | |
I also used that kit the first time my truck was lowered. I got shock extenders with the kit. In the front I used 2.5 " lowered spindles and a round cut from the coil springs, that netted about a 5" drop.
88 Chevy C1500, step side, LS swap. 98 Crew Cab Dually, tow rig. 03 Dodge Neon. ECTA Ohio Mile record holder. |
08-07-2009, 06:23 PM | #8 |
454, did you have to drill a hole for the new bump stops?
08-07-2009, 07:07 PM | #9 |
Gen III Power
I was going to use these off of ebay, but they dont inlcude any hardware or shock extenders....
http://cgi.ebay.com/ebaymotors/73-87...Q5fAccessories For the $90 the DJM seems like a good bang for the buck...Plus it includes all the parts you need.
---Bob--- '81 Long Box. 2005 5.3l Vortec and 2005 4L80e coming soon... |
08-07-2009, 08:28 PM | #10 |
If you have a welder save $50-60 and weld on some new spring perches. If you plan on going to the track and have some decent torque then you may possibly rip the existing perches off and screw up your driveshaft.
I did this a few years ago, sucked getting towed home from the track.
83 C10 Stepside (SOLD, it was a blast!) 383 MASS-FLO EFI/TKO II 600/3.90 Posi 10 bolt S475 and C4 DM running, fine tuning turbo= Douchebag Racing: Runs Fine all the Time |
08-07-2009, 10:35 PM | #11 |
I have not bothered to install them. But yes, drilling a hole would be required.
- Greg |
08-07-2009, 11:40 PM | #12 |
If I recall correctly, you do not have to drill for new bumpstop, take old one out, put new one in same hole.
I have that djm kit, did not use shock extenders, they fit like crapola anyway. Get some drop shocks.
1986 C10 SWB 6.0/6l90e Miami...Flee it like a native |
08-08-2009, 03:21 AM | #13 |
thanks 454, you've been alot of help. i'll post pics after i'm done.
