08-07-2009, 12:49 PM | #1 |
Stuck 3rd member .. any ideas?
So I'm tearing down my rear end for a rebuild and I can't get the 3rd member out..
It's a 12 bolt out of my '66 C10. I've got the main caps off, I pulled the large pin out that goes through the spider gears. That literally took me an hour of hammering to get out because it was worn/swelled/locked/rusted in there. The axles are also out.. I just can't get the third member to budge.. do i just need to get a bigger pry bar and some more muscle behind it? I can tell that moisture has been in there before, there is a good amount of pitting on the teeth of the ring gear. Am I missing something else that's holding it in? I don't see any thing else that could be other that it could be rusted in to place.. Thanks for your help! |
08-07-2009, 01:15 PM | #2 |
Re: Stuck 3rd member .. any ideas?
git a LONG pry bar, and ideally someone else to hold the third member, and pry on it. some rear ends i do, it takes me and my boss both with 4 ft. prybars to pry a carrier out. if the carrier has the holes on the sides, bout 1" round, pry one side and then the other. Hope this helps
08-07-2009, 02:55 PM | #3 |
SSN 706
So this is one of those times you don't need a bigger hammer?
Daverods 64 C10 Daily driver 292 3 speed "Driver" Daverods 66 Build C10 Bags 350/350(On Hold) Daverods 52 Build 3100 S10 chassis,Bags, 350/700r4 "Click it" Last edited by daverod; 08-07-2009 at 02:55 PM. |
08-07-2009, 04:51 PM | #4 |
Its one of those He-Man Butcher things. They have case spreadders for those tough ones. All the ones Ive ever messed with just fell out.
08-08-2009, 12:09 AM | #5 |
60-66 Nut
Yeah sometimes they are stuck in there pretty good, Like was already posted, a good pry bar and another person is a good idea. Someone to catch the carrier and help and try and keep track of which shims came from what side.
08-08-2009, 12:31 AM | #6 |
Got it out! I went to Harbor Freight and got a nice long pry bar for $6 .. me and a buddy pry'd it right out, no problems..
Thanks! |
08-08-2009, 07:33 AM | #7 |
Any time you can find a reason to buy tools is a good thing.
James 63 GMC V6 4speed carryall 65 chevy swb bbw V8 auto 68 K20 327/4 speed, buddy buckets 2002 GMC CC Dually Duramax 64 GMC lwb 3/4 V6 4speed SOLD 66 GMC swb bbw buddy buckets SOLD IG duallyjams The only thing that stays the same is constant change! |
08-08-2009, 09:09 AM | #8 |
SSN 706
Way to go. I love hf. Went there the other day got a $30 creeper board for $15.
Daverods 64 C10 Daily driver 292 3 speed "Driver" Daverods 66 Build C10 Bags 350/350(On Hold) Daverods 52 Build 3100 S10 chassis,Bags, 350/700r4 "Click it" Last edited by daverod; 08-08-2009 at 09:10 AM. |
