Old 08-04-2009, 10:06 PM   #1
Misled
Misled's Avatar
Crooked Frame?
I'm hoping for some help.....
When I got this truck, I was amazed that it had absoultely no rust and I believe it is oem metal everywhere. When I took this truck apart, I didn't see anything that would have led me to believe that the frame was bent (body lines). Once I had it on the stand yesterday, something just didn't look right.
I put a string on it from the measured center of the front cross member to the measured center of the rear. The measurement on the front half from side to side are all off. I then put strings on either side and "eyeballed" them to line up along the rear section (I realize a small error at the back could multiply up front) and it seems to be off.
I'm assuming that the frames from the factory were symetrical. the last couple pics show what I think are wrinkles.
Are there "wrinkles" from the factory?
Is this frame "tweaked"
Anyone got a cheap SWB 2wd 1978 frame?
As always, thanks for the wealth of knowledge!!!!!
Misled
Misled is offline   Reply With Quote
Old 08-04-2009, 10:07 PM   #2
Misled
Misled's Avatar
Re: Crooked Frame?
...last two...
Old 08-04-2009, 11:26 PM   #3
heavychevy79
Cheyenne Super
heavychevy79's Avatar
Re: Crooked Frame?
I see where it was straightend in the 2nd from the last pic, but in the last pic
that looks like the part just behind the cab, and that one side of the frame looks bent on all trucks, it's bowed down where the other side is flat.
The wrinkled part should be repairable.
heavychevy79 is offline   Reply With Quote
Old 08-04-2009, 11:26 PM   #4
N2TRUX
Happy to be here
N2TRUX's Avatar
Re: Crooked Frame?
In the last set of pics, the bottom one is correct. That is a curve the factory put there to clear those old humongous catalytic converters.
The other pic is a different story. All those wrinkles are all wrong. It appears that the frame was tweaked and someone did a hack job on trying to straighten it out.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 08-05-2009, 05:34 AM   #5
rod86
great southern land
rod86's Avatar
Re: Crooked Frame?
yep, looks like it was really bent at some stage, it should be able to be fixed, but it will take alot of heat to get the creases out, and i dont like heating chassis..
rod
86 chevy c10 silverado
rod86 is offline   Reply With Quote
Old 08-08-2009, 03:08 PM   #6
Misled
Misled's Avatar
Re: Crooked Frame?
....that's what I was afraid of.....I guess I'll start looking for a donor frame!!!
Thanks folks!!!
Misled
Old 08-08-2009, 04:32 PM   #7
SBTork
Garage wrench
SBTork's Avatar
Re: Crooked Frame?
Thanks folks!!!
Misled
That or take the bare frame to a local frame/collision shop and see what they can do for you. It may or may not be the cheaper option.
-Adam
90 V1500 GMC Suburban 350/700R4/NP241.....
01 Saturn SL1 stock DD.....
SBTork is offline   Reply With Quote
