69 cab on 67 frame ?s
Ok so Im sure its been asked but Im not having any luck finding the question in the search.
So we got a 67 chevy that needs a cab and I have a rust free 69 cab. now then here is the question. Do I order 67 cab mounts or 69 cab mounts? I know a few people on here have talked about 67-68 having the cab mounts on the frame sitting a little higher up than the 69-72 frames. So making the 67-68 mounts thinner than the 69-72 ones. Is this correct? Would I just need to buy 67-68 rubber mounts an be ok with the 69 cab on the 67 frame? |
its all about the +6 inches
Re: 69 cab on 67 frame ?s
they should be the same.
If the frame is a 2 wheel drive 1/2 ton, then order those mounts, if it is anything else, then get the other mounts. |
Watch out for your cornhole !
![]() Join Date: Jun 2003
Where you're getting confused is the core support mounts being different between the two. The cab mounts are the same though. Just order 1/2 or 3/4 ton mounts, whatever is appropriate for the frame.
Awesome guys and thanks for the info. Just got the rusty cab off today for my cousin. Now he will be cleaning the fram a little then maybe if I get the time I can hook him up with a 5 lug suspension for it. New 67-72 nut in the making and at a verry young age.
