Old 08-08-2009, 05:28 PM   #26
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Re: can it be my heads?
you need to verify that your engine is that hot.
Since you are giving numbers, and not saying "the H on the guage" I'll assume you have an aftermarket guage hooked up.
Is this an electric guage, or mechanical?
Old 08-08-2009, 05:34 PM   #27
drewfever1020
its a mechanical
drewfever1020 is offline   Reply With Quote
Old 08-08-2009, 08:50 PM   #28
drewfever1020
ok i did my compression test today!
8 115psi 7 110psi
6 105psi 5 120psi
4 150psi 3 115psi
2 125psi 1 134psi
as u can see they are in plug order!
what does it look like to u?
Old 08-08-2009, 09:15 PM   #29
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Slow down and think through things first. Why would you just jump to a conclusion that it's the heads all of the sudden ?
I could understand if it were using water or blowing steam out the exhaust.
I'm on the Instagram- @Gearhead_Kevin
Tx Firefighter is offline   Reply With Quote
Old 08-08-2009, 09:19 PM   #30
drewfever1020
it can be a blown head gasket too!
i knw its somthing internal cuz i got 2 elec fans and it still gets hot on me!
Old 08-08-2009, 09:23 PM   #31
Tx Firefighter
If it's a blown head gasket your compression will suffer and you will use coolant causing steam to come out of the exhaust. Your compression numbers are good.
Old 08-08-2009, 09:29 PM   #32
drewfever1020
well im not making this up but my exhaust does realease some ugly smell and it burns my eyes
Old 08-08-2009, 09:30 PM   #33
Tx Firefighter
If it burns your eyes, it is running too rich. Steam smells sweet and it it quite noticeable. And I never implied you were making anything up.
You've thrown a pile of money at the problem with no improvement so far. I thought you might want some advice from someone who did this stuff for a living for a long time. Carry on. Throw more cash at it.
Old 08-08-2009, 09:32 PM   #34
drewfever1020
so what can the problem be?
i have everything for the cooling system brand new
Old 08-08-2009, 09:33 PM   #35
Tx Firefighter
It is using a noticeable amount of antifreeze ?
Remove all 8 spark plugs. Go to O reilly and borrow their pressure tester. Pump the cooling system to 18 psi and see if any water comes out of any spark plug holes.
Yes, you have a head gasket or cracked head problem. No, your heads and gaskets are fine. It's that simple.
Old 08-08-2009, 09:41 PM   #36
drewfever1020
ok i will do the pump thing 2marrow since its already late
but when i took my spark plugs out today they were all black and smelt funky kinda like antifreeze
Old 08-08-2009, 09:47 PM   #37
Tx Firefighter
Barring a blown gasket or cracked head, you can quit worrying about the heads as your problem. There's not something that can just go wrong with them and cause your problem other than that.
Old 08-08-2009, 09:49 PM   #38
drewfever1020
well ill take another look tommorow thanks man
Old 08-10-2009, 07:19 AM   #39
Ole Blue 68
Ole Blue 68's Avatar
If it's hitting 200 and staying there then I don't think you have a problem at all.
Ole Blue 68 is offline   Reply With Quote
Old 08-10-2009, 09:05 AM   #40
drewfever1020
it goes to 2 hundred then it goes to 210!
like i said i have 2 electric fans on is pushing and one is pulling!
thats not right cuz one fan should be able to keep it cool!
i was reading around and my truck has symptoms of a blown head gasket!
bubbles coming from antifreeze when u look in cap
the exhaust smells sweet and burns my eyes
the truck doesnt run good
why plugs are all wet and black
Old 08-10-2009, 09:09 AM   #41
70k52wd
Blaze-Air
70k52wd's Avatar
Post #35, what TxFF said to do. Do that.
70k52wd is offline   Reply With Quote
Old 08-10-2009, 09:37 AM   #42
drewfever1020
i did that yesterday
i could only get to 12 psi and it pops off on me
i rented the kit from advance cause they didnt have it at orielys
Old 08-10-2009, 09:51 AM   #43
Jim_PA
Burning eyes can be rich or lean. What is your timing at idle?
Jim_PA is offline   Reply With Quote
Old 08-10-2009, 12:38 PM   #44
Ole Blue 68
Have you had to add any coolant?
Also, check your oil for any signs of coolant on the dipstick. What some people call a milkshake.
Old 08-10-2009, 06:34 PM   #45
mclairmo
Plugs are wet and black because carb is too rich. If head gasket was leaking, it would likely overheat, not just run at 210 degrees, which is arguably a 'normal' temp. Or, it would blow white smoke out the tailpipe or blow water out the radiator or you would see oil mixed in with your coolant or water on the oil dipstick. I would keep tweaking the cooling system as I mentioned above instead of pulling the heads. One fan may not keep it cool if the fan does not pull enough air through the radiator or if there is no shroud, or if the water pump pulley is too big, etc. There are many reasons why you could still run hot with even two fans. Are you sure the fans are running at 100%? Proper size wiring and proper use of relays are needed to feed those high amp fans. You may also need a higher amp alternator to feed two fans. I am also not convinced that you are truly runnning abnormally hot. I also don't like your compression numbers. There is a huge varation from high to low. That indicates a possible problem to me, maybe ring gaps are not proper, some cylinders are worn, burnt valves, etc.
mclairmo is offline   Reply With Quote
