Old 08-10-2009, 05:33 PM   #1
broncos33
Gas tank
Anyone know of a good not to expensive aftermarket gas tank that will fit between the rails of our 72 Chevy?I was looking at one from summit but i dont know if i can connect a hose to relocate the filler neck it looks like i would have to cut a hole in the bed and dont want to do that.Any help would be appreciated.
THANKS ALEX
broncos33 is offline   Reply With Quote
Old 08-10-2009, 09:16 PM   #2
csa daddy
csa daddy's Avatar
Re: Gas tank
try useing one from a newer blazer or suburban an the filler neck will go out past the side of the frame rail an you can run up in between the bedsides an make a little hinge for a side marker light an put the filler behind the marker lens on the side of the bed
csa daddy is offline   Reply With Quote
Old 08-10-2009, 09:24 PM   #3
JUSBLAZ
JUSBLAZ's Avatar
Re: Gas tank
PM coming your way
JUSBLAZ is offline   Reply With Quote
Old 08-11-2009, 09:25 AM   #4
turp mcspray
turp mcspray's Avatar
Re: Gas tank
I run a 73 up blazer tank in my 72. I moved the filler neck over to the driver side and hooked it up to the original tank fill hose.
Turp Mcspray
New life for an old 2wd, farm blazer
http://67-72chevytrucks.com/vboard/s...d.php?t=505987
My Blazer build http://67-72chevytrucks.com/vboard/s...d.php?t=342299
turp mcspray is offline   Reply With Quote
Old 08-11-2009, 10:27 AM   #5
broncos33
Re: Gas tank
Thanks for the reply was starting to think no one was out there.What years do you recommend 90's 2000's.THANKS AGAIN
Old 08-11-2009, 11:01 AM   #6
csa daddy
csa daddy's Avatar
Re: Gas tank
i wana say the article i seen it in the used a 73-91 model blazer tank
itt was pretty cool looking
Old 08-11-2009, 11:38 AM   #7
vtblazer
vtblazer's Avatar
Re: Gas tank
Here's 22 threads found using the search function, maybe there's some good info for you in one of them.
http://67-72chevytrucks.com/vboard/s...rchid=1292645y
vtblazer is offline   Reply With Quote
Old 08-11-2009, 12:03 PM   #8
broncos33
Re: Gas tank
Thanks for the help
Old 08-11-2009, 12:20 PM   #9
JUSBLAZ
JUSBLAZ's Avatar
Re: Gas tank
Here's the one I was talking about.
