Old 08-10-2009, 08:05 PM   #1
chirishtown
chirishtown's Avatar
Bench Seat adjustment spring?
A spring popped off under my bench seat ('69 pickup) for the forward and back seat adjustment. Every now and then when I am driving the seat moves and I pop the lever back into place but I need to fix this. Not sure where I am supposed to reconnect the spring? Hopefully this makes sense. I pick would be nice so I could see a connected spring. Thanks.
chirishtown is offline   Reply With Quote
Old 08-11-2009, 04:56 AM   #2
JimKshortstep4x4
Re: Bench Seat adjustment spring?
You will want to reconnect the spring that came off. Is it the small one that pulls the lever back or is it the large one that assists the seat to slide?
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end
1965 Impala SS 400 sbc, Muncie rock crusher
1966 Impala SS 396 bbc, TH 400
1969 El Camino, 350 sbc, TH 350
1971 Snowplow built on a Blazer frame
1972 GMC Short bed, stepside, TH 400, 427 BBC
Old 08-11-2009, 06:04 PM   #3
chirishtown
I don't see any springs attached. I think the spring I found is probably the larger one. I can take a pic of it if it will help. I can put the lever in place but if I hit a bump in the road it comes loose and the seat moves etc...
Old 08-11-2009, 07:55 PM   #4
JimKshortstep4x4
You may be missing the spring for the lever. Here is a picture of the spring that holds the lever in position. Also, the larger seat assist spring is shown.
If you don't have the small spring, check with your local hardware as they may have a selection. (My local ACE Hardware has almost the exact spring in their selection).
Jim
Old 08-12-2009, 12:55 PM   #5
chirishtown
Ok yes I have the small spring for the lever (forward and backward adjustment). I see how it attaches. I may need the big spring. I will look for it in the cab. Do you have a pic of the big spring attached? I really appreciate your help.
Old 08-12-2009, 01:25 PM   #6
rwolf9653
more ideas than money
rwolf9653's Avatar
On my 67 the longer spring is bolted to a bracket on the floor. It runs from there to the drivers front seat bracket. But the truck has been through a lot and this might not be original or correct.
Randy
1948 Chevy 3100 5 window
1966 Chevy C30 Dually
1967 Chevy K10
1972 Chevy K20
1972 Chevy C10
1972 Chevy K5 Blazer
1987 Chevy V10
2003 Chevy Suburban
rwolf9653 is offline   Reply With Quote
Old 08-12-2009, 04:55 PM   #7
rwolf9653
rwolf9653's Avatar
I looked at my 72 and the long spring is not there. Sorry.
Randy
1967 Chevy K10
1972 Chevy K20
1972 Chevy C10
1987 Chevy V10
2003 Chevy Suburban
