Old 08-09-2009, 09:30 PM   #1
AusMarty
Am I using the right fan belt
My 1980 350 equiped c20 threw a fan belt and ever since replacing it the belts don't seem to last too long, the altenator and water pump seem to spin fine, the belt I just got is an 11A1145, when I was at the parts store I tried a 13A but it was to wide.
Am I missing something here ?
AusMarty is offline   Reply With Quote
Old 08-09-2009, 10:28 PM   #2
79gmcc15
Gettin It One Pice At A Time
79gmcc15's Avatar
Re: Am I using the right fan belt
just a thought, but, have you checked to make sure the pulleys aren't bent? that could cause pre-mature wear.
RIP ELJAY
Work In Progress 1979 GMC C1500 Trailering Special.
Getting the truck done, one piece at a time.
“You can tell a lot about a fellow’s character by his way of eating jellybeans.”Ronald Reagan
“I don’t know the key to success but I know the key to failure is trying to please everybody.” Bill Cosby
79gmcc15 is offline   Reply With Quote
Old 08-09-2009, 11:46 PM   #3
AusMarty
I checked the pulleys and the bottom ones do have a bit of a wobble in them, I also heard a bit of a clicking noise in that area so I took off the fan belt and the noise is still there , I am thinking of a possible cracked pulley, I'll take them off tomorrow and check them out.
Old 08-12-2009, 10:09 AM   #4
AusMarty
I found the problem !!, The altenator pulley was worn causing the belt to slip when it loaded up Running sweet now
Old 08-12-2009, 10:20 AM   #5
silvereagle07
silvereagle07's Avatar
What was the clicking noise you heard? With the belt off , the crank pulley is the only thing turning. Glad you got the problem fixed.
Jeramy
'84 GMC project truck
'85 Chevy 4X4 SOLD
'07 Chevy Trailblazer SS
5th Annual SHPHC Car/Truck Show Pics
http://67-72chevytrucks.com/vboard/s...d.php?t=543605 UPDATED PICS! CHECK 'EM OUT
silvereagle07 is offline   Reply With Quote
Old 08-12-2009, 07:35 PM   #6
AusMarty
It may have been the power steer pump or belt, it was fairly tight, when I re assembled it the noise was gone
