Old 08-12-2009, 01:24 PM   #1
glendale
glendale's Avatar
700r4 trans tunnel and crossmember?
what are you guys doing to put 700r4's in your trucks?
glendale is offline   Reply With Quote
Old 08-12-2009, 01:32 PM   #2
ratskin
Re: 700r4 trans tunnel and crossmember?
Pretty straightforward-I had to move the crossmember back and drill new holes, and shorten the driveshaft 3 inches. Make sure the shaft is lined up with a dial indicator before welding. Mine was a factory auto, so I bought a Lokar kit which is adjustable enough to set the shifter correctly. The pointer is only correct at Park and L, but I think I've seen a bezel that should work, designed for the 67-72s. I believe the columns are the same diameter, so at worst, I'll have to drill new mounting holes for it.
ratskin is offline   Reply With Quote
Old 08-12-2009, 01:34 PM   #3
ratskin
BTW, you have to have the correct yoke. I can't remember what I used, but it's different from the Powerglide. I think a 400(?).
Old 08-12-2009, 06:40 PM   #4
glendale
glendale's Avatar
what did you do with all of your ebrake stuff?
Old 08-12-2009, 07:12 PM   #5
toms84ss
Yoke is same as a TH350. I bolted mine in with a CCP trans crossmember. I started with a roller and had no motor or tranny to start with.
toms84ss is offline   Reply With Quote
Old 08-12-2009, 08:15 PM   #6
shortbed70
shortbed70's Avatar
I havent put mine in this truck yet but my other had no ebrake stuff and it was move xmember,redrill and shorten driveshaft.
Troy
1965 Chevy Bagged,361 sbc,voodoo cam,1.5 full roller rockers,patriot 185cc vortec heads 2.02-1.60,vortec weiand polished intake,demon carb
my truckhttp://67-72chevytrucks.com/vboard/s...d.php?t=332884
Big Red Dog build
http://67-72chevytrucks.com/vboard/s...d.php?t=572274
shortbed70 is offline   Reply With Quote
Old 08-12-2009, 09:32 PM   #7
toms84ss
Why would the E-brake be affected by the transmission that's in the truck???
Old 08-12-2009, 09:52 PM   #8
protrash64
Resistance is Futile
protrash64's Avatar
I'm not certain, but I think there is a lever or cable junction that hooks on the trans X-member and is affected by moving the X-member. Read it on a thread awhile back...you know how that goes.........
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash
64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban
66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852
STRENGTH/DETERMINATION/MERCILESS/FOREVER
.......posted via stationary device
protrash64 is offline   Reply With Quote
